FRM VIN change problem
Old Oct 29, 2015 | 01:39 PM
2tonebb6's Avatar
2tonebb6
So my frm kicked the bucket a few months back and I replaced it with a used unit. I just plugged in the newer unit and most of my functions were restored(windows,fog lights etc.) but I need to change the VIN and VO to match what my car originally had. The problem I'm having is getting the old VIN to change to my original. I used NCSexpert to get my VIN with checksum and then went into tool32 and ran frm_70.prg and placed my full 18 digit VIN into the argument line and executed the job c_fg_schreiben. When I went back to NCSexpert the frm VIN had not changed at all. I then decided to give Winkfp a try and within comfort mode I chose frm2 and entered my VIN but the text line is only long enough for 17 digits. So i tried it without the checksum and it it said it succesfully flashed the frm. Now when I check the frm VIN in NCSexpert it still hasn't changed. I've attempted both programs several times with the same result and am pretty much stumped. Has anyone else had problems changing their VIN with tool32 and Winkfp?
Old Nov 1, 2015 | 10:32 AM
sgscomps's Avatar
sgscomps
Modules are coded to the car so getting one used will not work correctly in your car and you won't be able to change the vin to match your car.
Old Nov 1, 2015 | 03:04 PM
2tonebb6's Avatar
2tonebb6
That is partially correct. The modules are coded to the vehicle's VO(vehicle order) and their VIN. These can be reprogrammed via tool32 and NCSexpert. My question wasn't whether or not it could be reprogrammed but rather why I can't get tool32 or Winkfp to change the VIN accordingly.
Old Oct 2, 2016 | 12:23 PM
justawatcher's Avatar
justawatcher
resolved?
I'm having similar problems.. did you figure this out?
Mine is Kombi related.. shows correct vin when queried but incorrect vin at tach
Old Oct 5, 2016 | 12:49 PM
MiniToBe's Avatar
MiniToBe
false! I programmed and change almost all of the module on my MINIs with the exception of the CAS and DME.
Old Oct 5, 2016 | 12:51 PM
MiniToBe's Avatar
MiniToBe
i use Winkfp and NCS expert to the get the coding and programming done. you need Ediabas 73 and the latest SPDatens.
Do you also have INPA"?
Old Oct 5, 2016 | 01:58 PM
justawatcher
INPA v5.0.6
ISTA/P 3.56.3
WinKPF v5.3.1 (SP_Daten_V59)
NCS-Expert v4.0.1 (SP_Daten_V59)
I started a new thread..
https://www.northamericanmotoring.co...pf-update.html
phil_deez
Oct 13, 2016 03:26 PM
Jan 14, 2016 11:42 AM
TJANK
Oct 13, 2015 04:45 PM
anks
12
Oct 13, 2015 11:21 AM
bahman
Sep 30, 2015 01:59 PM
