Replacing used bcm???
Old Oct 29, 2015 | 08:54 AM
audio131's Avatar
audio131
Hi. Having a wiper and sprayer issue where they turn on by themselves. Tried new battery.i really think the bcm is messed up.. i have a 06 r53.. can i get a similiar yr bcm and just plug it in?
Old Oct 29, 2015 | 10:57 AM
The BCM , 61356982114
I have heard of a couple people getting lucky with a BCM on exact options and model , but only a couple people have it work. Most of the time it require a new BCM which then has to be flashed to the car by a MINI Dealership.
https://www.northamericanmotoring.co...le-issues.html
Old Oct 29, 2015 | 09:37 PM
audio131's Avatar
audio131
Bcm
Im going to try and get a used wiper switch. Much cheaper and maybe it may fix it. Im completly puzzled on whats causing it..
Old Oct 30, 2015 | 08:49 AM
You can try the wiper stalk first but if the BCM got wet or you have a sunroof and water leaked into the floor area , that might point to the BCM. The stalk is the cheaper part to try first , make sure you get the right one , with the yellow flasher end and itf you have auto wipers or not. Thanks
Old Nov 3, 2015 | 03:43 PM
nkfry's Avatar
nkfry
If you go per the bible you must buy a new BCM and code it to the car, that said you can plug a used BCM into your car and fix your issue for 85% cheaper than a new unit.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
erblo
R60/R61 Stock Problems/Issues
Dec 31, 2017 01:46 PM
wrnchhd
Jan 7, 2016 10:45 AM
silence2-38554
Nov 6, 2015 11:36 AM
bneer
Oct 23, 2015 03:18 PM
audio131
Oct 12, 2015 10:29 AM
