wipers and sprayer turn on by themselves and wont shut off
Old Oct 12, 2015 | 09:16 AM
audio131's Avatar
audio131
Had my windshield washer and wipers and rear wiper turn on for by themselves today as i was driving.washer shot out all the fluid and kept running i had to pull over and remove a few fuses..anyone see this before or have an idea whats causing this?
Old Oct 12, 2015 | 09:26 AM
Hobine's Avatar
Hobine
Never had the washers run by themselves, but my rear wiper motor developed a mind of its own. I had to pull the fuse to stop it. Mine would also blow the washer fuse.
I tried every thing I could think of and ended up deleting the rear wiper. No more blown fuses and the washers work as they should.
I believe there is some kind of short in the rear wiper motor that was reeking havok.
First thing to check is the battery though.
Old Oct 12, 2015 | 09:53 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
A good place to start might be to test your battery. When the battery is on its way out, all sorts of weird electrical gremlins can appear. There is a DIY here with directions on how to test it. This may not be your issue, but it's a good place to start.
888.280.7799 | 6am - 5pm PST
Old Oct 12, 2015 | 10:26 AM
audio131's Avatar
audio131
battery
Could be. Bought the car a month ago. Dealer sorta screwed me a things i didnt catch..battery was replaced but noticed it not right one .no vent ports either.. And only tested marginal 12v
Old Oct 12, 2015 | 10:29 AM
PelicanParts.com
Vendor
I've seen batteries bad at 12v. A normal battery should read a voltage slightly above 12 volts with the car sitting still, and no electrical devices on. A typical reading would be in the 12.6-volt range when the battery is fully charged. If the reading is 12 volts or less, then the battery needs charging or needs to be replaced with a new one.
twriter
R58 :: Coupé Talk (2012+)
16
Feb 1, 2016 10:54 AM
ej
Nov 13, 2015 07:39 AM
greentrees
Oct 12, 2015 02:19 PM
67veloce
Oct 11, 2015 10:01 PM
Jim Ferrell
Oct 9, 2015 10:09 AM
