R56 mcs outside air temp sensor faulty
Subscribe
Sep 25, 2015 | 09:03 AM
Hi guys, my car thinks its hotter then the actual temperature. Im looking to replace the sensor, where is it located exactly?
Reply 0
Sep 25, 2015 | 09:34 AM
I believe it's attached to the lower grill on the front bumper. You can easily see the sensor if you shine a light on it through the grill on the drivers side. It is pretty simple to remove the bumper to replace the sensor. DIY on bumper removal here. If needed, 65-81-6-936-953, enter promo code COOPER at check out to save 10%.
Reply 0
Sep 27, 2015 | 03:29 PM
Quote: Hi guys, my car thinks its hotter then the actual temperature. Im looking to replace the sensor, where is it located exactly?
My Mini is like that as well, my mother's car also. I find it more accurate in the colder months because the assault that the car sits on or drives on can be 140F, that's going to exaggerate the temperature readings especially in the hotter Summer months. I wouldn't pay much attention to your Mini's temperature gauge.
Reply 0
Sep 27, 2015 | 05:03 PM
You can access it by the passenger side wheel well. Undo a few plastic Phillips head screws, fold back the liner and you'll see it.
Reply 0
Sep 29, 2015 | 12:53 PM
Yea behind theat bumper on the driver side. 65816936953
https://www.northamericanmotoring.co...calibrate.html
We also carry a repair kit as the plug itself can sometimes get damaged.
Reply 0
Jan 19, 2018 | 01:54 PM
OK...so which is it...behind the bumper on the driver side? Or behind the bumper and accessible thru the right front wheel well?
Thanks...
Reply 0
Jan 19, 2018 | 02:07 PM
Behind the bumper and accessible thru the right front wheel well - been there done that!
Reply 0
Jan 19, 2018 | 03:16 PM
Quote: Behind the bumper and accessible thru the right front wheel well - been there done that!
Thanks so much.
Bill
Reply 0
Subscribe
