Strange Check Engine Light Problem
Old May 19, 2015 | 04:56 AM
eyan212's Avatar
eyan212
I have a 2005 JCW with several modifications. The Check Engine light came on indicating a lean fuel mixture. I drove it for a few months before I had time to fix it. I found a crack in the hose between the throttle body and the intake. That has now been fixed.
The strange (and frustrating) issue is the Check Engine Light will still not clear. My local mechanic has checked everything we can think of and there are no mechanical problems with he car. He can clear the code but then it immediately comes back when the key in turned on. It will even (not always) throw the code before the engine is running. He thinks I should go to a dealer and have the ECU re-flashed. I'm not so sure. It sounds like a faulty sensor or electrical issue to me.
Any thoughts?
Old May 19, 2015 | 06:47 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
What is the code (s)?
Old May 19, 2015 | 07:08 AM
ZippyNH's Avatar
ZippyNH
What's the code...
If it throws a code without the engine running...kinda indicates a bad sensor....
If the sensor is "out of limits" with the car off...it will throw a code...when my t-map failed, it would throw a code with the motor off....
Does the ecu show a "pending code" before the light turns on?
Old May 19, 2015 | 07:25 AM
eyan212's Avatar
eyan212
The code is P2090. There are no pending codes.
This code is new after the repair and there is nothing wrong with the camshaft.
Old May 19, 2015 | 05:34 PM
eyan212's Avatar
eyan212
Anyone have any thoughts?
Old May 29, 2015 | 09:32 AM
eyan212's Avatar
eyan212
So, after a week at my Mini dealer they called me and asked if they could return the car to stock and then begin to diagnose the problem. What?!? They said with all the aftermarket parts they cannot diagnose the issue.
Here's te problem: The only aftermarket part related to the engine that is not a Mini JCW part is the cold air filter. Everything else is suspension related.
Needless to say, my answer was "NO WAY!!"
Old May 29, 2015 | 10:09 AM
Minnie.the.Moocher
Choice #1, find a good Indy shop!
Choice #2, give in to the fact that Mini has a set procedure for diagnosing troubles. I'm assuming that some of your parts are not factory, so they want to go back to square one. If you put a decal on the windshield they probably will want to scrape it off. Find a good Indy mechanic.
Old Jun 7, 2015 | 04:51 PM
ptkacik's Avatar
ptkacik
What is wrong with installing the original air filter? If that helps them T-shoot the problem, why not? What is a cold air filter anyway? Doesn't the original air filter get its air ahead of the radiator anyway? That is what a cold air intake is supposed to do.
BTW, we did a study on air filters and found that the standard square Fram air filter from Wal-mart had the same pressure drop as the expensive tubular reusable ones. The tubular ones often get their air behind the radiator so getting cold air becomes harder.
Just a thought.
Peter
Old Jun 26, 2015 | 06:20 PM
CGaboury's Avatar
CGaboury
A p2090 is a mini specific code. It's based on a stored code that you can't clear with a normal obd2 scanner. You need to either have he dealer clear your adaptations. Or get yourself the BMW INPA software and cable.
You'll need to clear all adaptations and then clear one memory. Then it'll be gone.
If you're in the New England area, I can clear this stuff for you. I'm in Rhode Island.
Don't waste your time stripping parts from the car. Mini is just trying to get money from you.
Old Jun 26, 2015 | 06:55 PM
AZdsrt's Avatar
AZdsrt
P2090 B Camshaft Pos Actuator Ctrl Circ Low Bank1
VANOS solenoid maybe?
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
