Need some help and advice on my engine problems
Old Jul 4, 2017 | 09:09 AM
  #26
seandallen's Avatar
seandallen
Carbon Blasting
Originally Posted by 05r50
My MINI dealer charged bout $850 for walnut blasting (2 years ago).
Most independent MINI shops are bout $400 for the same.
To inspect it you remove the air box and then the intake which is below the air box. The ports face away from you so you need to use a snake camera or a mirror and flashlight to check the buildup.
Post up what area you are from and someone may be able to tell you of good place for that service
+1 on the carbon blasting. You may not have CEL codes, but you will eventually get misfire ones. Do it every 50-60K miles with a spark plug change, and your engine will thank you. You can do it yourself for about $250 investment (one time), and 4 hours of your time. Pelican Parts has an EXCELLENT walk-through on the procedure.
To get to the throttle body, you had everything removed to do the carbon blasting already.
Old Jul 5, 2017 | 08:09 AM
  #27
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Thanks for the post seandallen! Yes, we have a different method (the method used before the adapter) here: http://www.pelicanparts.com/techarti...n_Cleaning.htm. This saves you money from purchasing the equipment needed to walnut blast. It is still a very effective method. Let me know if you have questions.
888.280.7799 | 6am - 5pm PST
Old Jul 5, 2017 | 11:37 AM
  #28
holkki's Avatar
holkki
Hey
I had similar idle problems with my friend R56MCS -08(87 tkm). normally run quit "normal"but idle was very bad,almoust stopped then revs jumps between 1550-2000rpm, then stalled! NO CELS! ,no misfires. we thought,it must be HPFP,NO!,then check timing,allright!,then compression,ok! everything seems normal,but then we find problem!,bad Vanos solenoid!!! we had once cleaned it,but does not check working with powersupply.It is jammed,thats why "dynamic timing",Vanos does not working and makes very bad idle. I hope,that helps you!
Zettinger
Aug 25, 2015 04:04 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
Aug 12, 2015 01:24 PM
massmini03
Aug 12, 2015 11:19 AM
mdorn98
Aug 11, 2015 08:49 AM
