Oil leaking 2 days after change
Old Jan 18, 2015 | 12:16 PM
Daa_bob's Avatar
Daa_bob
So i went to my local shop to get my oil changed and everything was fine for the rest of the day. The next morning i came out to about 3 quarts of oil on the ground. I thought it was just the filter housing leaking but it does not seem to be coming from there. Does anyone know what the issue could be? thanks in advance
2004 MCS
Old Jan 18, 2015 | 12:19 PM
bavmotors's Avatar
bavmotors
I would check the drain plug first, then pull the filter housing make sure the o ring is intact and reseat the housing.
Old Jan 18, 2015 | 01:27 PM
ZippyNH's Avatar
ZippyNH
I might bet $$ it is the filter cover o-ring....or the drain plug...
Fill it up...turn it on and look for drips...
Yeah..clean oil is hard to see...
Old Jan 18, 2015 | 01:31 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
3ltrs would be a lot for housing cap leak since it's higher than pan. Maybe they only finger tightened the drain plug.
Old Jan 18, 2015 | 01:36 PM
ZippyNH's Avatar
ZippyNH
True...I was thinking syenthic oil spreads out so fast....a little makes a HUGE puddle...
Old Jan 18, 2015 | 01:40 PM
-=gRaY rAvEn=-
Moderator
yeah maybe just looks like 3.
Any oil showing on the dip stick ?
Old Jan 18, 2015 | 01:56 PM
Capt_bj's Avatar
Capt_bj
a full cap leaking out would be a BIG mess
feel around the cap and inspect the area below (flashlight) ... when you spill oil from the cap on a change it can make a BIG mess in the area (including flooding the control arm bushing and the oil speeds deterioration .. but I digress)
it is possible all you are seeing is the residue of a poorly done change . . . .
bad o-ring blows oil under pressure first ... I left an oil ring around the neighborhood from a test drive after a change where I'd piched the ring!
Old Jan 18, 2015 | 04:37 PM
Daa_bob's Avatar
Daa_bob
thanks for the responses. it was definitely at least 3 qt. and there is no oil registering on the dipstick
Old Jan 18, 2015 | 06:32 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Pull the filter and check the oring, with that much oil that is the most likely cause.
http://www.waymotorworks.com/oem-min...0-r52-r53.html
Old Jan 19, 2015 | 04:01 AM
fastzombie's Avatar
fastzombie
I have experienced the damaged oil filter o ring problem. It sure dumps a lot of oil when that has been messed up during installation.
Old Jan 19, 2015 | 05:17 AM
JAB 67's Avatar
JAB 67
If the OP is taking his car to an independent for an oil change he is not likely able to pull the oil cannister cap to check for an o-ring.
Old Jan 19, 2015 | 07:09 AM
bavmotors's Avatar
bavmotors
perhaps he just doesn't feel like doing it, let's give him some credit.
Old Jan 19, 2015 | 07:13 AM
Daa_bob's Avatar
Daa_bob
Thanks guys turns out the o-ring was sliced on installation. i do usually do my own oil changes however its is 30 degrees here and i don't have garage to work inside of
Old Jan 19, 2015 | 09:08 AM
bavmotors's Avatar
bavmotors
ik the feeling
Old Jan 19, 2015 | 10:21 AM
quikmni's Avatar
quikmni
Glad you found the problem.
Too bad you had to take it to someone to do the work (or make more work for you).
Old Jan 19, 2015 | 11:11 AM
ZippyNH's Avatar
ZippyNH
Yup...been there done that...last winter...
Thought I was saving myself an hour...took longer to cleanup than if I had done it myself!!
sprp85
Aug 22, 2015 06:16 AM
Lex2008
Aug 16, 2015 08:33 PM
FLYM1N1
Aug 16, 2015 01:17 PM
azntaiji
Aug 13, 2015 03:24 PM
wind715
Aug 11, 2015 07:56 AM
