Where to purchase new PS Pump?
Old Jan 13, 2015 | 07:52 PM
Lt. Dan's Avatar
Lt. Dan
So I have an interesting failure- my Power Steering Pump is actually grounding out the OBD connector so that I can't flash my computer, check codes, or get my emissions testing done. As soon as I unplug the pump, I can talk to the PCM just fine!!!
So, where is the best place to buy a replacement pump at this time? What prices are you seeing?
Old Jan 13, 2015 | 08:21 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We keep them in stock
New OEM
http://www.waymotorworks.com/oem-pow...ring-pump.html
or we now have an aftermarket one. It's a little more cost effective, but has a higher core cost and 1 year warranty
http://www.waymotorworks.com/afterma...0-r52-r53.html
Old Jan 15, 2015 | 05:57 AM
We have them here also: 32416778425
http://www.ecstuning.com/Search/SiteSearch/32416778425/
What year are you, I would also see if it would fall under the PS pump : I don't know if they would classify that as a PS failure, might want to call your dealership.
Also would be a great time to have a look at the P/S lines while you are there.
For certain years there is a recall from MINI on the pump and fan if it fails : https://www.northamericanmotoring.co...50k-miles.html
For the power steering pump , its electrical pump and see here :
https://www.northamericanmotoring.co...fan-issue.html
Here is the power steering lines parts and DIY:
https://www.northamericanmotoring.co...hose-pics.html
Thanks and good luck.
Old Jan 16, 2015 | 06:43 AM
Lt. Dan's Avatar
Lt. Dan
Thanks for the info! Unfortunately, I already ordered a pump (will be here today). I did check into the recall/warranty extension, and unfortunately my R53 has 188K miles, so I'm out on that... At least it doesn't look like a hard job...
Old Jan 16, 2015 | 06:52 AM
ZippyNH's Avatar
ZippyNH
Just be sure to pick up the RIGHT PS Fluid...
The system does not use convenental fluid, but a syenthic, and is not compatible...
Chf-11 I think...a quick serch will confirm it...
Mini dealers have it, vendors, most VW dealers, and SOME auto parts stores...ask..it might be a counter item.
Old Jan 16, 2015 | 07:05 AM
Lt. Dan's Avatar
Lt. Dan
Thanks Zippy, I'm lucky in that regards... Have an AWESOME euro parts company locally
Old Jan 17, 2015 | 04:23 AM
JRhea's Avatar
JRhea
For anyone else needing a pump I picked mine up at NAPA last year. It's a Dorman remanufactured and has a NAPA no questions asked lifetime warranty. The pump is quiet unlike the original
Old Jan 17, 2015 | 09:06 AM
aslondon's Avatar
aslondon
Advance Auto has the CHF 11s fluid in stock. its about 24-26 dollars a can.
Al
Old Jan 17, 2015 | 06:18 PM
David.R53's Avatar
David.R53
I sent mine to Module Masters and had them rebuild it for $225 with a 5 year warranty. So far I have about 6 months on it without trouble. Its been very quiet. Supposedly better than stock.
http://modulemaster.com/rebuilds/sho...i-cooper-epas/
Get the CHF-11S fluid on Amazon for $14-$17 liter depending on brand.
Old Jan 17, 2015 | 06:50 PM
mellenberger65's Avatar
mellenberger65
Found out mine was covered under the extended factory warranty for excessive pump failures after a replaced it. Unfortunately I did not buy the replacement from the Mini dealer (even though it was the exact same brand as the original) so thaey would not reimburse me.
Love the Mini... not so much our local dealer.
(They are within 20 minutes of the house but I would rather order out of Memphis then buy from them). :(
Old Jan 19, 2015 | 05:51 AM
Bearybee's Avatar
Bearybee
www.bba-reman.com Has the pumps for $350 plus shipping or pump amd fan for $425 plus shipping. They do their own remanufacturing and offer a lifetime warranty.
Old Jan 19, 2015 | 06:08 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
There is an "extended warranty" of sorts thru your dealer. 02-some 05's up to 150k miles. It includes when needed the harness you are having issues with. Last I knew, the harnesses are ordered by VIN for each case to prevent dealers from over stocking them.
GL!
Old Feb 27, 2015 | 03:30 PM
Fizzyx's Avatar
Fizzyx
Hey Dan,
How did you diagnose that it was your PS pump?
My 02 R53 had a complete electrical shutdown 25 feet from home (got lucky there). The steering had felt odd for the last few days - like it did not want to center itself but the effort was normal.
I disconnected the battery, charged it up, and pulled the 100 amp PS fuse, got the car started and got the car home. I checked the battery voltages and it looks like it and the alternator are working. Given the repair cost for the pump I am looking to positively diagnose it as the culprit.
Cheers,
-Fizz
danielbrookes_9
Oct 3, 2015 12:51 PM
Marco Guardado
Sep 15, 2015 01:22 AM
HaveATank
Sep 4, 2015 08:04 AM
smarsha11
Aug 24, 2015 06:03 AM
kpl
Aug 11, 2015 04:52 AM
