speedometer is wrong
Old Dec 9, 2014 | 06:34 PM
jeffl's Avatar
jeffl
My mini came with 15" wheels from the factory. I bought it with no wheels so I put 17" factory mini wheels and I believe my speedometer is off. Is there a way to re calibrate it?
Old Dec 9, 2014 | 07:23 PM
hsautocrosser's Avatar
hsautocrosser
They are all off from the factory on purpose. The diameter of your wheel does not affect it but the diameter of your tires can. Dealers won't/can't correct it and I haven't seen anyone offering a reprogramming service to do so either.
Old Dec 9, 2014 | 07:33 PM
jeffl's Avatar
jeffl
Oh. So is the odometer off as well?
Old Dec 9, 2014 | 08:03 PM
rkw's Avatar
rkw
The factory MINI wheels come with tires that are very close in diameter (even when the wheel size is different).
It is normal for the speedometer to read high in all BMW and MINI vehicles. Actually it is intentional by the manufacturer. There are a zillion threads by owners complaining about this. I believe that it can be adjusted in NCS Expert programming.
The odometer is accurate and unaffected by the high speedometer reading.
Old Dec 9, 2014 | 08:19 PM
jeffl's Avatar
jeffl
Thanks for the replies. I wont worry about it.
Old Dec 9, 2014 | 09:43 PM
AudioNToxication's Avatar
AudioNToxication
If you can read the speedo from a scangauge or some little Bluetooth thing it will be more accurate. The gauges read differently. That's why the odometer can still be correct
Old Dec 9, 2014 | 11:16 PM
ZippyNH's Avatar
ZippyNH
What size tires did you get? Are they an OEM size?
Getting an "alternative" size can save a few $$, and reduce gap, but can sometimes make the 2-3 stock speedo error worse....
Old Dec 11, 2014 | 10:19 PM
RiverCityRocker's Avatar
RiverCityRocker
I had an old Ford truck I put 33 inch tires on. Speedo never worked right after that. I just drove around at what I thought was OK. I passed a co-worker on the way to work one morning and he said I flew by him and he was going 80mph. I must have been doing 90+. If you can't get it rectified, be careful you don't drive too fast.
In my Mini sometimes I look down and I'm surprised I'm driving so fast. After 5 year of riding nothing but a motorcycle I have a hard time gauging my speed without the wind blowing on me.
Old Dec 12, 2014 | 12:14 AM
rkw's Avatar
rkw
Actually the opposite. Reducing gap (with larger tire diameter) would reduce the high speedo reading and make it more accurate.
Old Dec 12, 2014 | 10:48 AM
hsautocrosser
He didn't specify larger diameter, just "an 'alternative' size."
Old Dec 12, 2014 | 04:43 PM
Fizzyx's Avatar
Fizzyx
However he also said 'reduce gap.' Which if interpreted as reducing fender-tire gap would mean a larger than stock diameter which in turn, would reduce the higher than actual speedometer reading.
Old Dec 12, 2014 | 06:37 PM
hsautocrosser
He provides three possible consequences of getting a size different from OEM. He doesn't specify size in absolute nor relative diameter. Nor does he say which of the possible consequences will actually occur:
You can save money, and [you can] reduce gap, but you can sometimes increase speedometer error.
It is not the best writing but with spoken inflection and pauses at each comma it would be clear.
Old Dec 13, 2014 | 04:59 AM
eaglebeagle's Avatar
eaglebeagle
if you have a smart phone, get a speedo app and see how far off you ar, make a note of it. on android I use "Ulysse Speedometer" seems pretty close to what those highway speed signs say, +/-1 mph. i went from 15s to 16s on my 08 cooper and that brought me to 2-3 off from 5-6 off. So i think you may be pretty close to right on.
Old Dec 13, 2014 | 11:20 AM
jeffl's Avatar
jeffl
I do have a app on my Iphone. According to the app the speedo is about 4-5mph faster then it. So thats good based on the way I drive to work.
ccfirelt
Oct 18, 2015 01:02 PM
TunedGP
Oct 1, 2015 04:18 PM
simo711
Oct 1, 2015 05:36 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
TifosinDel
Sep 28, 2015 10:45 AM
