Lights on my dash
Old Aug 12, 2014 | 11:17 AM
mhopper49's Avatar
mhopper49
Lights on my dash
Ok so for a few months I have had a few lights on and I guess its time to figure out what the problem is. There are three lights that are constantly on. They are my traction controll light, my ABS light, and my tire pressure indicator light. any idea what could be causing this. I have took it to a few places and no one has the correct adapter to read the codes. Please Help and Thank you.
Old Aug 12, 2014 | 02:52 PM
Capt_bj's Avatar
Capt_bj
search here for "trifecta" .....
you most likely have a bad wheel speed sensor ... this causes all three of the mentioned systems to think there is a problem due to bad wheel speed being reported
problem is, you don't know which one is bad ...you need the "very good" code reader to get that info and in many cases than means going to the dealer unless you have a GOOD MINI smart mechanic
once you know which one, it is not a particularly difficult repair ... the sensor just screws into the hub and connects to a wiring harness ... sometimes the old one is a PITA to get out . . .
Old Aug 12, 2014 | 03:12 PM
cristo's Avatar
cristo
Alliance Member
You can unplug the sensor connectors, connect to the leads and check for the pulses with an
analog multimeter or an oscilloscope while spinning the wheels to see which
sensors work and which don't, but that's a bit of work.
Old Aug 12, 2014 | 03:21 PM
mhopper49's Avatar
mhopper49
So I am guessing that each wheel has its own sensor?
Old Aug 12, 2014 | 03:25 PM
JABowders's Avatar
JABowders
Veteran: Army
Yes, as an example: that is how the system measures the wheel speed to determine if the TC needs to come on.
Old Aug 12, 2014 | 03:27 PM
cerenkov's Avatar
cerenkov
Couldn't you just buy one sensor, pick a wheel at random and install it. If it doesn't fix the problem then swap it around until it does. (assuming that all 4 are the same part).
You have a 25% chance right of the bat.
Old Aug 12, 2014 | 05:10 PM
bmwr606's Avatar
bmwr606
a professional grade obd reader (not the $50 variety, the $1200+ variety, will show which wheel sensor is not reading ... I had the same issue on my p/u truck and my buddies scanner found the bad sender by looming at the raw data as we drove around the block ... his was a snap-on that he uses in his transmission repair business ... it has plug in modules for each brand/year
Old Aug 12, 2014 | 07:00 PM
cristo's Avatar
cristo
Alliance Member
Front and back sensors are different.
Old Aug 13, 2014 | 08:05 PM
AudioNToxication's Avatar
AudioNToxication
Or, if your power steering had been leaking for forever, start by cleaning the connector on the dream real that's covered in crap. That's all mine needed. It was coming in every day, since cleaning it, not one in several thousand miles.
triple5soul
Nov 19, 2019 07:46 AM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
Super Coop
Aug 17, 2015 05:09 PM
AZN Optics
Aug 16, 2015 11:52 PM
