2002 R50 starting issues
Old Aug 3, 2014 | 02:47 PM
atomic5150's Avatar
atomic5150
I bought a 2002 R50 for my teenage daughter a few weeks ago and its a really cool car. Unfortunately, I stalled it in reverse at start up. Now when attempting to engage the ignition, it won't turn over or click. Everything else works that requires power. I was stranded and it would push start to get it home. Any thoughts?
Old Aug 3, 2014 | 03:17 PM
minsanity's Avatar
minsanity
Dead or dying battery. Check that 1st.
Old Aug 3, 2014 | 04:47 PM
ZippyNH's Avatar
ZippyNH
Then....
A car with a bad starter, bad ews (antitheft) system, or clutch interlock switch can cause similar issues...
But battery is most likely...volts may be fine...but not enough smps.
Old Aug 3, 2014 | 08:09 PM
atomic5150's Avatar
atomic5150
Checked the battery
Thanks for the fast responses. Put it on a trickle charger for 6 hours and still nothing. The chime works when the key is in the ignition. Even tried jumping it and nothing when the key is turned to the start position. Thoughts?
Old Aug 3, 2014 | 08:49 PM
Fly'n Brick's Avatar
Fly'n Brick
Clutch pedal CLEAR to the firewall? Not knowing your driving history it is easy for those unfamiliar with manual gearboxes to forget about that pesky clutch. I've seen it happen, helped by suggesting just that to a guy once who couldn't get his son's car to start. Also, if that battery is over three years old I'd give it vote of no confidence.
Old Aug 3, 2014 | 08:57 PM
atomic5150's Avatar
atomic5150
Yeah, it goes all the way in. I've had the car for a few weeks and have been doing minor repairs to get it roadworthy. This started after stalling it in reverse. The battery is 2 years old. Arizona conditions are horrible on batteries. They usually last 2 years. After a full charge from a charger, No noise when turned over. After hooking it up with jumper cables, Nothing???? Starter Relay????
Old Aug 4, 2014 | 07:40 AM
Fly'n Brick
Zip mentioned the clutch interlock which would be worth investigating and the relay could certainly be a contributor. I've been scratching my head trying to get it around the reverse gear stall evolution having anything to do with it though.
Old Aug 4, 2014 | 09:20 AM
ZippyNH's Avatar
ZippyNH
The "ding" when you put the key in should means the ews is OK....
Try anything old school....like hitting the starter with a hammer? Heck...check the grounds...lots of corrosion could cause issues...always like to do the simple, easy, cheap(free stuff) first...
Old Aug 7, 2014 | 09:21 PM
atomic5150's Avatar
atomic5150
So, here's the update. Yesterday after consulting a wiring diagram. I checked all the fuses that pertain to starting, charging, interlock and clutch switch. They were all good. Then backed the car out of the garage to try jumping again, this time with my Silverado. i realized that the previous attempt was with my wives Camaro and it uses remote terminal posts under the hood. So with the cables hooked to the silver ado battery and the pos to the Mini battery and the negative to the chassis we went for it. First turn of the key nothing, back to off position and the second try it fired up. So i replaced it with a new 47 series battery with 650cca and 810 ca its still dead. Any thoughts???
Old Aug 8, 2014 | 01:00 AM
minsanity's Avatar
minsanity
Check the ground. Had this happen to me in my RAV4.
Old Aug 10, 2014 | 12:41 PM
atomic5150's Avatar
atomic5150
Ground is good, have 12.6V at the main starter cable connection When the key is turned I've got nothing at the solenoid.
Old Aug 10, 2014 | 12:57 PM
ZippyNH's Avatar
ZippyNH
Maybe the key assembly is bad....it has contacts, etc...
Try some contact cleaner?
Old Aug 10, 2014 | 01:54 PM
atomic5150's Avatar
atomic5150
Thanks Zippy. That's next on my plate.
Old Aug 10, 2014 | 02:53 PM
atomic5150's Avatar
atomic5150
So here is the latest........... Checked ignition switch function with the schematic. Everything (the fuses) has power when it should. I can also hear the clutch start module switch when the clutch is pushed in. Car will still bump start when needed, still no turn over at starter.
Old Aug 12, 2014 | 06:49 PM
atomic5150's Avatar
atomic5150
Ok, so this just happened. Checked the key signal by holy
Ding it to the cylinder and the chime started. I'm assuming the key is good and the ewc because I have a signal. So, I'm gonna tear the column apart. Try starting 1 last time and nothing. Tilt the column up to take apart and decide to try it again and VAROOM!!!!!!! There is something related to the column position and it's ability to start. Gonna sleep on this tonight. I hope to have many ideas tomorrow. Thank you all for your help and support.
Old Aug 12, 2014 | 06:59 PM
JABowders's Avatar
JABowders
Veteran: Army
Can it be a loose connector under the column plastic? Maybe a pinched wire... Hmmm ?
Best of luck.
Old Aug 12, 2014 | 08:06 PM
atomic5150's Avatar
atomic5150
I took the switch out and rinsed it with cleaner. It still starts in the upper positions and not in the lowest setting. Double checking the wiring.
Old Aug 13, 2014 | 04:35 PM
atomic5150's Avatar
atomic5150
Problem was the connector for the ignition switch. Disconnected the battery and bent the female terminals in a little. Packed it with dielectric grease and it works fine now. Thanks to everyone for the help. Now on to my power window problems.
Old Aug 13, 2014 | 05:41 PM
ZippyNH's Avatar
ZippyNH
Good to hear you figured it out!! Wow....talk about an odd thing to have happen!!
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
Teh
Jun 13, 2018 02:59 PM
triple5soul
21
Jul 29, 2016 04:27 AM
rphox2003
Aug 5, 2015 11:34 AM
