now the Horn has taken a dump...
Old Apr 24, 2014 | 05:31 AM
astroBlackMetallic_Mini's Avatar
this mini really is starting to fall apart all around me, despite keeping good maintenance on it....
now the damn Horn has taken a dump. it sounds like a weak sauce childs power wheels car horn, meeeh meeeeh. (was wondering why my wailing on the horn to a-hole drivers was not getting me any reactions!)
wtf is up with this? ive hardly ever hear of a horn taking a dump like this, yes the car has a lot of miles (106k), but its only 7 years old.
is this a "common" issue? the only "upside" is its an excuse to put a harbor freight air horn in there somewhere (except my entire workshop is packed away in a garage in another city )
i find myself posting in the "stock problems and issues" section more and more now. its getting depressing!
Old Apr 24, 2014 | 05:38 AM
ZippyNH's Avatar
ZippyNH
You actually have 2 horns....
So one has been dead a bit...that's why it sounds so odd...easy fix...universal or exact fit.
....might be a good excuse to upgrade to a airhorn...aka like a truck or train...can be quite interesting on a car as small as a mini!!
Old Apr 24, 2014 | 05:54 AM
Yep , set in right be hind the bumper in front of the wheel well.
61337193996 is the low tone horn.
http://www.ecstuning.com/Search/SiteSearch/61337193996/
61337193997 is the high tone horn.
http://www.ecstuning.com/Search/SiteSearch/61337193997/
This sits above the front fog light on the passenger side of the core support.
You could try to get it from the wheel well but I don't want you to damage the core support bending it back.
I would suggest taking the bumper main skin off and then replacing it there.
Looks like you have the correct part.
Here is a link to a helpful guide: Just get to the bumper cover part and you can access the horn. You should not have to take off any support metal bracing.
https://www.northamericanmotoring.co...front-end.html
Another option is to go with the Hellas: Which are very similar in design to OEM.
http://www.ecstuning.com/Search/SiteSearch/UN6628500/
or Air trumpet kit if you really want to be loud.
http://www.ecstuning.com/Search/SiteSearch/UN6627400/
Old Apr 24, 2014 | 06:22 AM
Minibeagle's Avatar
Minibeagle
The OEM horns are poop. I am the 2nd owner of a 2006 JCW and the horns were replaced twice: once by the original owner and once by myself.
I had the same problem that the OP described. One horn completely failed and the other one (high tone) sounded like it belonged on a clown's car. When I removed them, I found that both contained water!
I replaced them with Hella Supertones last fall.
Old Apr 24, 2014 | 06:57 AM
wb123mb's Avatar
wb123mb
+1 for the way too loud fog horn... but I don't know where you'd be able to mount them
Old Apr 24, 2014 | 11:05 AM
yetti96's Avatar
yetti96
I'll jack this thread...4 trumpets and a 4gal air tank.
Old Apr 24, 2014 | 11:25 AM
wb123mb's Avatar
wb123mb
Holy hell,
so you just refill your 'horn tank' whenever it starts going flat? how long does that last you? I bet that thing sounds like the apocalypse coming.
barnoun
Sep 17, 2018 05:04 PM
martinb
Oct 7, 2015 05:00 PM
one73ronin
23
Sep 22, 2015 09:56 AM
trw92a
Aug 26, 2015 01:47 PM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
