Sporadic Hatch Functionality
Old Apr 2, 2014 | 08:54 AM
OCVeloman's Avatar
OCVeloman
The hatch will sometimes open and sometimes close. Other times it just slams and bounces (receiver mech won't lock it shut). I must've fiddled with it and tried closing it 10 times before i turned the car on and drove, shut it with the car on and it finally stayed closed. Go to drive and hear it pop itself open 15 seconds after it latched. Closed it again and it finally seems to stay shut.
I searched and found many similar situations but none with resolution after replacing electronics or chrome for black hook. Mine is already black, by the way.
Old Apr 2, 2014 | 11:05 AM
ashchuckton's Avatar
ashchuckton
The striker on the body has some adjustment available. You might try there.
What condition are the boot hinges in? I've seen them bend due to not being lubed. They bind up & the hinge bends. making the boot not line up correctly. They will eventually break in half if not kept
lubed.
You are sure it is not the boot handle causing this?
Old Apr 2, 2014 | 04:03 PM
OCVeloman's Avatar
OCVeloman
Actually got a ton of replies when i posted it in the wrong section.... Think they figured it out!
https://www.northamericanmotoring.co...tionality.html
PsychoRallye
21
Feb 17, 2019 06:08 AM
RobbyD
Jan 29, 2019 01:22 PM
gar56
Nov 15, 2016 06:41 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
