'05 Mini Cooper S: Instrument Panel Dim/ RPM dip / Supercharger Noise
Old Apr 3, 2014 | 07:59 AM
Chad Wulleman's Avatar
Chad Wulleman
I currently own an '05 Mini Cooper S and have been having several issues outlined below:
- dimming / brightening instrument panel lights
- dipping RPM's 150-200 RPMS at idle
- Supercharger whirring sound
All 3 of these things are happening simultaneously. These are the repairs I have had so far:
-New power steering pump, because it failed, the other issues began after this
-New alternator, had no affect on the above issues
-New voltage regulator, no affect on the above issues.
If anyone has any possible ideas on what could be causing this. My concern is that over a prolonged period this will cause serious damage to the car.
Thanks in advance,
Chad
Old Apr 3, 2014 | 05:56 PM
JRhea's Avatar
JRhea
How many miles does it have? My 02 R53 is pulsing the headlights and dash lights as well. There's a similar post a few prior to yours. I also replaced PS pump and fan. While my high and low speed radiator fans works fine I don't think the PS fan is energizing. I marked the fan and housing with a dab of paint and the blade has not changed position. The fuse is fine I need to research what relay drives the PS fan
iggi
18
Feb 9, 2026 01:00 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
