3rd Brake Light Replacement
Old Mar 1, 2014 | 05:39 PM
IDOXLR8's Avatar
IDOXLR8
Has any one replacerd a 3rd (middle) brake light in a 2003 MINI? I tried to relpace mine and it will not clear the roof spoiler, do I need to remove the roof/hatch spoiler? Thanks on advance, AL.
Old Mar 1, 2014 | 07:13 PM
InhumanElmo's Avatar
InhumanElmo
I just did mine the other day. I have an S with a wing and it cleared no problem. I have read that you may need to either take off the wing or remove/loosen the screws holding it on and moving the wing a bit. I would do a quick search and take a look.
Old Mar 1, 2014 | 08:10 PM
IDOXLR8's Avatar
IDOXLR8
Mine is a not a "S" model, what year is your MINI?
Old Mar 3, 2014 | 05:30 AM
IDOXLR8's Avatar
IDOXLR8
Not much action on my post I did some more research and found the hatch spoiler needs to be removed, I probably won't mess with it and put the light back in the box, AL.
Old Mar 6, 2014 | 01:32 PM
TheMINIPartStore's Avatar
TheMINIPartStore
The spoiler is only held on with a couple nuts. It is really easy to remove.
Old Mar 7, 2014 | 03:18 AM
IDOXLR8's Avatar
IDOXLR8
I must be missing something here, I took the 2 nuts out and this this stuck down with some kind of adhesive, don't want to break it, AL.
Old Jul 26, 2014 | 02:09 PM
IDOXLR8's Avatar
IDOXLR8
Where is everbody on this! Well I'm reporting back and have replaced my center brake light on my 2003 MINI. Yes it was a "PITA" and poorly engineered for a replacement stan point! I bought a set of 3 plastic scraper/chisel set from Snap On and worked pretty good but a great deal of care is needed to protect the rear soft out side window molding/weather strip because the tool will be laying against it. The tool must be to outside angles (facing you) and not forcing the tool in to far, just enough to have the light assembly clear. Do not insert the tool on the out side edges, work the soiler from the rear side to side of the lens. If I can help out let me know. AL.
Dec 23, 2015 10:36 AM
fjork_duf
Tires, Wheels, & Brakes
Aug 16, 2015 04:38 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
