Morse Code Noise at High Speeds?
Old Jan 12, 2014 | 06:36 AM
deputydog95's Avatar
deputydog95
So I was on a closed course in Mexico yesterday....
Anyway, the car makes this weird, really loud noise at speeds above 95 mph. It literally sounds like morse code and its loud. Obviously it's some sort of vibration.
It's not rpm dependent as it doesn't do it at higher rpm's in lower gears. And it's not gear dependent as it will do it in 4, 5, and 6.
I can't be the only person who's experienced this but I'm new to the car.
It's sounds like it's coming from the dash or hood cowl area. My guess is it's wind speed related but beyond that I don't know.
Old Jan 12, 2014 | 03:59 PM
Da_Ghost's Avatar
Da_Ghost
I'd check all the outside trims around the windshield, etc. It doesn't take much of a gap for air to make noises.
Old Jan 12, 2014 | 05:45 PM
kg4fxg's Avatar
kg4fxg
Valves
I wonder if it could be valves not seating properly at higher RPM? Which is related to the Cam Shaft lobes.
Just guessing ..... first thought that came to mind and I have not taken apart a Mini but other cars.
Old Jan 12, 2014 | 06:08 PM
minibx's Avatar
minibx
I have the same issue, it did it today, I've had this issue since I got the car over a year ago, I thought it was maybe the flywheel and clutch issue, it's kind of metal on and off but it sounds as if it was coming out of the dash as mentioned above it's speed related , it doesn't happen all the time at the same speed, but it does it from time to time. Performance is not affected but I wonder what could happen in the future if it keeps happening.
Old Jan 12, 2014 | 06:53 PM
deputydog95
The only reason I do not think it's that is because it doesn't happen in any of the lower 3 gears when I run it right up to red line.
You have to be going at least 90-95 plus. So I assume it's something wind related. But who knows?
It is really really loud though.... Very odd.
Old Jan 12, 2014 | 06:55 PM
deputydog95
What is the minimum speed for you to hear it?
Old Jan 12, 2014 | 07:02 PM
minibx's Avatar
minibx
For the first time today the lowest speed was around 73 mph but it will start at around 90
Old Jan 12, 2014 | 07:15 PM
minibx's Avatar
minibx
A few months can come and go before the noise comes back, I changed my clutch back in Oct.... I think,,, anyways the noise didn't show up again until a week ago then again today.
Old Jan 13, 2014 | 05:28 AM
deputydog95
Weird. Hopefully we figure this out. It's really disconcerting.
Old Jan 13, 2014 | 09:18 AM
minibx's Avatar
minibx
It is weird, I'll try to record it next time and post it, maybe someone else is having the same issue
Old Jan 13, 2014 | 06:43 PM
Da_Ghost's Avatar
Da_Ghost
If you think that it's only wind related, buy a roll of wide painter's tape and mask what you think create the noise, edges of windows/trims, etc. You can go by elimination from there.
Old Jan 13, 2014 | 07:08 PM
minibx's Avatar
minibx
Thanks for the suggestion but I'm 95% sure that it's not wind related! I wish it was lol
maestro39
Oct 27, 2015 02:38 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Pyrs
R55 :: Clubman Talk (2008+)
19
Sep 8, 2015 01:43 PM
David.R53
Sep 1, 2015 06:49 PM
