Defroster
Old Jan 11, 2014 | 06:03 PM
safeharbor's Avatar
safeharbor
Defroster
Hi Folks-stupid question. When I turn on my defroster, it is always on full fan speed. Is it possible to use the defroster with a lower fan speed? Thinking that there must be a way. If so, how do I adjust? Thanks!
Old Jan 11, 2014 | 06:18 PM
danjreed's Avatar
danjreed
Yes, just turn the speed down. It still works fine.
Old Jan 13, 2014 | 05:36 AM
safeharbor's Avatar
safeharbor
That's what I thought, but it changes back to non-defrost as soon as I adjust the speed. Not normal then??
Old Jan 13, 2014 | 08:16 AM
danjreed's Avatar
danjreed
Hmph, never played with it now that you mention it.
I know there are two sets of vents up top...
Old Jan 13, 2014 | 09:00 AM
exocet's Avatar
exocet
I always assume that was WAD and the defrost button was more of a "shortcut" to pressing fan to max and directing it to windscreen only.
In any case the behavior is the same on mine. If you want a lower speed, just turn the speed down and make sure the windscreen button is the only direction selected (not feet or face) - effect is the same :-)
Old Jan 13, 2014 | 09:59 AM
JeffM's Avatar
JeffM
To avoid having the defroster fan go to high initially, instead of just quickly pressing the defroster button, push it in and hold it for 2-3 seconds. The air flow will switch to the windscreen but the fan speed will remain where it was before.
Old Jan 13, 2014 | 11:09 AM
safeharbor's Avatar
safeharbor
Ok, will try that!
Old Jan 19, 2014 | 07:13 AM
safeharbor's Avatar
safeharbor
That Did It-Thanks!!
NYXF56JCW
Nov 17, 2024 05:06 AM
Ntety
Sep 2, 2015 08:39 PM
kristina
Apr 15, 2007 09:16 AM
drdave
17
Feb 18, 2005 06:42 AM
jsun
Oct 28, 2002 02:25 AM
