Unspecified maintenance due?
Old Dec 16, 2013 | 01:02 PM
BigCanoe's Avatar
BigCanoe
Hi,
My car is just about to turn 30,000 miles. The little car on a lift icon says I have 70 miles till service, which is of course, when it turns 30k. I stepped through the individual lights/indicators:
Front brakes - 1100
Rear brakes - 1400
Oil - 6000
Coolant - 11/14
So thats it, there is nothing pending that I can see. Why is the service light on, is there some generic catch all 30k mile service? The oil was changed when I bought the car from a dealership, about 4k miles ago.
Old Dec 16, 2013 | 03:06 PM
Slave to Felines's Avatar
Slave to Felines
If it's a 2012, you should still be eligible for "free" service. Let the dealer figure out what needs doing.
It's probably an inspection of some kind.
Old Dec 16, 2013 | 03:12 PM
BigCanoe's Avatar
BigCanoe
Ok, I dont making the trip but I dont wanna pay for anything
Thanks!
Old Dec 16, 2013 | 04:44 PM
Big Jim Swade's Avatar
Big Jim Swade
There is also some time based service required like the brake fluid needs changed every 2 years. All of these should show up in the service menu on the OBD.
Old Dec 20, 2013 | 12:09 AM
MiniDeLux's Avatar
MiniDeLux
The lift icon is something like a 60-point inspection. Mine goes in tomorrow for that exact service item.
I got you beat, though. My little lift icon is red and reads -800km (dealer told me it is easily put off). Car is serviced by an authorized Mini dealer and they told me it's not a critical service. I've got 120,000km on the clock and it's the first time this light has appeared.
I think basically what they do is check for leaks, mounts, suspension, bearings, etc... From what they tell me it's not expensive, either.
Old Dec 20, 2013 | 04:38 AM
BigCanoe's Avatar
BigCanoe
Wow, how random, thank you!
Old Dec 20, 2013 | 04:44 AM
yetti96's Avatar
yetti96
Just an inspection to look things over and no service is usually performed. Looking for bad hoses, belts, leaks, etc.
Old Dec 20, 2013 | 06:56 AM
InjectedGT's Avatar
InjectedGT
On the same topic, is the timer on the red "mini on a lift" service indicator something I can change on my own? Asked my SA last time I was there because I do all my own work, he goes "those lights and warnings can not be reset by anyone but a dealer. We reset them when doing the service. If you want us to just make sure you did a service and reset it for you, it would be $60".....
Old Dec 20, 2013 | 07:37 AM
Austinsynthetics's Avatar
Austinsynthetics
That statement is incorrect about only the dealer being able to reset those. I purchased the software, tho expensive, and can pull codes and reset them. Maybe someone local to you has software to do the same.
Old Dec 20, 2013 | 09:25 AM
millerb7's Avatar
millerb7
Originally Posted by BigCanoe
Hi,
Front brakes - 1100
Rear brakes - 1400
Oil - 6000
Coolant - 11/14 This is most likely not coolant and is actually your brake fluid.
See the red above.
Old Dec 20, 2013 | 09:48 AM
yetti96's Avatar
yetti96
Brake fluid every 2 years, coolant every 4 years. Inspection every 30k miles.
Old Dec 21, 2013 | 06:46 PM
richardsperry's Avatar
richardsperry
You can reset any service indicator yourself. (Brakes require a new sensor once they are activated)
You can't change the interval.
Sep 10, 2019 09:22 PM
weaver9000
Sep 14, 2015 05:48 PM
Sep 10, 2015 11:55 AM
ronn
Sep 9, 2015 07:12 PM
