07 Cooper S What TPMS System do I have?
Old Nov 5, 2013 | 08:08 AM
Mskminifan's Avatar
Mskminifan
I just picked up a set of used JCW two piece wheels that I want to install on my 2007 Mini Cooper S. I have a buyer for my existing set of Alloy wheels and tires, but before I sell I want to make sure I am not putting myself in a position t send more money.
The new JCW wheels have just a plain rubber valve stem.
My existing Allow Wheels have a rubber valve stem but not sure if there is a sensor or something internally or it it uses pressure and revolutions...
How can I tell without having a tire removed from my existing car?
Old Nov 5, 2013 | 09:31 AM
countryboyshane's Avatar
countryboyshane
I don't know of a way to check without the tire off the car. Might be something a vendor could tell you.
Old Nov 5, 2013 | 10:22 AM
InjectedGT's Avatar
InjectedGT
If you have rubber valve stems on an 07, your TPMS system is run through the ABS system. It's a relative system. Not a physical active system with sensors in the wheels. You're safe.
Old Nov 5, 2013 | 10:36 AM
Looks like you have the rubber valve stem from the picture , but I need a better one up close. Early 07' Gen 2 MINIs still had the simple wheel speed sensor (ABS ) reading system with the rubber valve. Then they went to the metal stems with the in wheel sensor , sensor bolts to wheel stem . See #7 and #8 pairing in the diagram below.
Like mentions above from injectedgt. Both have the rubber valve , then your good.
In this link I talk about the cutoff dates and time frames on the systems based off of production.
Here the link .
https://www.northamericanmotoring.co...h-10-13-a.html
Old Nov 5, 2013 | 10:56 AM
Mskminifan's Avatar
Mskminifan
Great information guys, thank you! How did we ever live without Forums to share information years ago?
Yep both wheel sets have the Rubber traditional valve stem so I am going to assume that it uses the Indirect Pressure system as described by ECS and InjectedGT and no hardware is used internally.
When I get a warning that pressure is low, it's just a general message. In my other vehicles I get a specific tire message (left front, Right rear, etc..) I guess that is another way of knowing I have an Indirect pressure system in place of the direct TPS system...
Does 2008 and up mini's give you a specific tire pressure warning when using the direct system?
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
