How to ziptie BPV
Old Aug 30, 2013 | 10:06 AM
AlexQS's Avatar
AlexQS
How to ziptie BPV
Hoping for replies from people who have done this, a couple of us have questions about it:
Originally Posted by Cease
I actually had the same question regarding the BPV. I can see it and touch it from the engine bay but am not sure what is supposed to be zip tied. I am running a 15%, stock crank and am seeing psi in the 12.5-13 range.
Maybe I'll look at mine this weekend, and see if I can figure it out. -I think I'm in the same boat, I can see it, touch it, just not sure what people are tying to. There's a pushrod that comes out of a vacuum diaphragm. I'm thinking to tie from where the end of the rod connects to the lever on the side of the BPV, and carefully wrap the zip tie around the back of the vacuum diaphragm.
Edit:
Did anyone else do it as I describe?
What exactly do you tie to what? (for the test)
Old Aug 30, 2013 | 12:20 PM
youloze's Avatar
youloze
That is exactly what I plan to do this weekend...effectively keeping the bpv closed at all times.
Old Aug 31, 2013 | 01:13 PM
AlexQS's Avatar
AlexQS
Not what I was expecting,... This is the BPV when the car is off, it rests against the stop with the pushrod from the vacuum diaphragm extended.
I started the car, and just parked at idle, the vacuum diaphragm pulls it all the way in the other direction.
I don't have an assistant here to operate the throttle while I watch the valve move.
At this point I'm thinking maybe the thing to do is pull the vacuum line off the diaphragm and cap it with a small bolt or something.
Got errands to run, I may have more info later.
(ugghh. Can't post the photo from my phone at the moment)
Later
Edit: I guess it posted the same photo twice
Attached Thumbnails How to ziptie BPV-image-3911133355.jpg   How to ziptie BPV-image-2972959290.jpg
Old Aug 31, 2013 | 01:30 PM
youloze's Avatar
youloze
I initially thought the same thing and zip tied it the wrong way (opposite from where it sits with the car off) and I got no boost lol. Zip tie it the way it sits when the car is off and that will build boost. Unfortunately I didn't gain any psi so I don't think its the bpv for me :-(
Old Aug 31, 2013 | 03:11 PM
AlexQS's Avatar
AlexQS
So I hear the DT-BPV will "close all the way" and the factory one doesn't.
I'll do some research to see if it's simply a matter of adjusting the stop, or if there's more to it than that. Mines 2005, so it already has a slightly heavier spring.
I'll wait till I can get new IC Boots, and the gaskets I need, remove it, clean it, adjust it to close farther and give it a try.
My concern is that I could inadvertently introduce a yoyo. I have a very slight yoyo now, but it's mild compared to what I've read.
andy@ross-tech.com
How to
489
Apr 17, 2024 02:28 AM
Teh
Aug 22, 2022 04:37 AM
slash695
Apr 26, 2016 06:27 AM
04indimcs
Sep 22, 2009 09:06 AM
enologuy
May 21, 2007 08:56 AM
