Another CC-ID-029 problem... HELP
Helly guys, I need an advice or a solution for a problem that appears yesterday after running (photo)... when I hit the apex the vibration take it off the k&n filter from the pipe and like magic it turns around and the flat side (one side has the hole and the other side of the filter is totally flat) cover the pipe (the suction pipe from the turbo) and immediately all the power was gone! (my bad...) but putting all in its place again a CEL appears (CC-ID-029) but my car runs and the idle is perfect... and searching on the web the code is the FUEL PUMP, other says that is the temperature (thermostat) and other says that it can be a bubble in the fuel line of a bad gas cap...
Opinions???
Thanks a lot!!!!!!!
Opinions???
Thanks a lot!!!!!!!
Drivetrain Problems M7 ags and my TAC... HELP!!!!
Glenns0245
Jan 11, 2007 09:05 AM
Storer
35
Jul 20, 2004 03:29 PM
