"hatch-open" light is possessed!!!
Old May 3, 2004 | 10:55 AM
EmCeeEss's Avatar
EmCeeEss
has anyone else had this problem?
the hood/hatch light comes on sometimes after i close the hatch, and i can re-close it a hundred times it won't go out... but an hour or two later (or after a shut-down, restart) it goes out by itself.
I am assuming this is happening with the hatch b/c i open and close the hatch, rarely touch the bonnet.
is this gremlins or a normal thing?
thanks :smile:
Old May 3, 2004 | 11:01 AM
jsun's Avatar
jsun
I have a hard time getting my light to go out, but that's because I have a hard time getting my boot closed properly. Alls I do though is to slam it and the warning light goes out. Since this doesn't work in your case, I'm thinking you probably have a bad switch. Get your dealer to check it out. If they're reasonable, they will probably just change it w/o making you replicate the problem (the part is probably all of about $5 bucks).
(btw, electrical gremlins ARE a bit of a normal thing on MINIs...IMO )
Old May 3, 2004 | 11:02 AM
joelz's Avatar
joelz
Yes, I've had the same problem a couple of times on my 2 month old MCS. Surfaced for the first time last week for a couple of days and hasn't been seen since...so far!
Old May 3, 2004 | 11:12 AM
911Fan's Avatar
911Fan
A new latch release mechanism should cure it. It contains a microswitch which tells the ECU that the hatch is latched.
Old May 3, 2004 | 11:15 AM
EmCeeEss's Avatar
EmCeeEss
thank you very much everyone...
glad to hear i'm not the only one. I'll swing it by the dealer when i get a chance....
thanks! :smile:
Old May 5, 2004 | 09:56 PM
DancesWithCones's Avatar
DancesWithCones
Coopsta had a similar problem. After a little investigation, it turned out the latch was very loose. It only took a 10-mil socket with extension to tighten. Neither he nor I could understand why it was loose but it was. I suggest you test it.
Old May 5, 2004 | 11:11 PM
goldcountrymini's Avatar
goldcountrymini
I have noticed with the MINI vs other cars that doors, bonnet, boot have to be closed relatively rough. I have not had the warning light act strange, but I will keep an eye out for the next few days-- I will report anything that seems to be strange.
Old May 11, 2004 | 05:27 AM
BMWNA's Avatar
BMWNA
I’m with MINI USA. I’m sorry to read about your problem with your hatch light. If you want our assistance, please phone us at (866) ASK MINI and mention Reference # 200413200028 so that we can help you more efficiently.
Old May 13, 2004 | 02:33 PM
lotsie's Avatar
lotsie
>>not rough but with conviction for sure :smile:
Old May 15, 2004 | 09:15 AM
Rick-Anderson's Avatar
Rick-Anderson
I have had the same problem with my MINI. To get the light to turn off, I have to 1) roll up the windows. 2) open and close the hatch door. 3) lock and unlock the doors with the key a couple of times. 3) let it sit locked for a few minutes.
Very frustrating. Ford Rangers have a very similar problem with the door ajar light. A quick squirt of WD40 on the latch solves it. I haven't tried that yet - don't want to void the warranty - LOL!
Old May 15, 2004 | 09:21 AM
pbraun's Avatar
pbraun
Why vent so much? Problem with car ? Just go to your MINI dealer service - it's called a 4 year/50,000 mile warranty.
I am sure it is an extremely fix. Good luck!
Old May 25, 2004 | 07:29 PM
Rick-Anderson
"Why vent so much? Problem with car ? Just go to your MINI dealer service - it's called a 4 year/50,000 mile warranty."
Here in SoCal there is a waiting list to see the dealer and it is a pain.
_________________
MINIs - Better than Prozak but without the side effects.
Aug 21, 2015 12:58 PM
Aug 19, 2015 12:51 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
