Main Engine Wiring Harness
Old May 20, 2013 | 12:28 PM
Yoda Mini's Avatar
Yoda Mini
How hard is this to replace?
My dealership wants $350 for this. Said about $10 in parts and 2 hours of labor. If I can save $240 doing it myself I would like to.
Are the wires in the below pic part of the Engine wiring harness?
Old May 20, 2013 | 01:04 PM
Hello,
I think i talked about this before, but did not know if you saw it.
https://www.northamericanmotoring.co...ese-wires.html
Thanks and hop that helps. Also , did you turn this into your insurance or did they not want to cover it?
Old May 20, 2013 | 02:24 PM
Yoda Mini's Avatar
Yoda Mini
ahh yes you did reply previously. I talked with the the Mini dealership again and he advised those wires (in my attached picture) are not the engine harness wires but that they will fix those also. I guess I never saw the damage that he is speaking of.
I am a little disapointed with the dealership becuase I just had my Mini in there 2 weeks ago for a $700 service which included a major inspection of everything but clearly they missed the engine wiring harness and the wires in my picture which are very obvious.
I didn't think about asking my insurance if it covers something like this. I will give them a call. Thanks.
Old Oct 14, 2016 | 12:05 AM
Al-Hajj Jameel Ibn Dawood's Avatar
On a related note...
I recently replaced the clutch, flywheel, thermostat, coolant hoses, and a bunch of other things while I was in there, and when it was all said and done, the Intake Air Temperature sensor connector crumbled due to age, as well as the wiring connector(s) that go to the thermostat. I've had a CEL for sometime now, and the codes read P0113 and P0128. The fan runs almost constantly, and stays on for ~7 minutes after the car is shut off.
It's absurd to pay $400 to replace the entire engine wiring harness for what are essentially two snap connectors. Is there a way to replace just the end fittings, or should I source a used component from the usual suspects?
Old Nov 9, 2016 | 07:27 AM
MonzMini's Avatar
MonzMini
I cant seem to find a single thread with a how to on reinstalling an ecu harness... anyone else seen something?
Old Nov 9, 2016 | 08:07 AM
MiniToBe's Avatar
MiniToBe
They dont seem cut!! shrink wrap them and you're good to go for now
Old Nov 10, 2016 | 01:42 PM
What are you connecting MonzMini? Replugging the harness or patching the wires?
Old Nov 10, 2016 | 04:28 PM
MonzMini's Avatar
MonzMini
Installing a completely new harness. I had pictures but the phone I had when I tore it down is very dead... It all seemed pretty easy until I got to the harness.
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
AZN Optics
Aug 16, 2015 11:52 PM
PSIChocolate
Aug 13, 2015 12:46 PM
DWooderson
Aug 10, 2015 09:12 AM
