Coolant leak - what part is this?
Old Mar 22, 2013 | 11:12 PM
jerrylee's Avatar
jerrylee
2004 Mini Cooper, base model, 84k miles.
I just topped off the coolant and bled the system, but on the test drive, I pop out and notice this leak. I don't have jack stands, so I'm not in a good spot to really dig in and figure out what's happening, but I did manage to snap two pictures. Can anyone identify what hose that is which is dripping coolant? It looks strange to me - it doesn't appear to be broken, the lines are much too smooth, it's simply... hanging there. It doesn't look right, that's for sure. That was my first hint - second was that it's dripping coolant, duh.
This is located in the center of the car, as far as left-right goes, and towards the back of the engine. (Edit: Clarification, it is far enough back that I can not clearly see it through the engine bay. I placed a light source under the car just next to the puddle - when I try to view that light through the engine bay, it is too far back to see. I can see the light, but I can't put eyes on the source. This is probably self-evident from the photo, as it is behind the front wheels.
Anyone please, what is this that is dripping coolant from my engine and scaring the bejeesus out of me please?
Attached Thumbnails Coolant leak - what part is this?-drip1.jpg   Coolant leak - what part is this?-drip2.jpg
Old Mar 23, 2013 | 03:14 AM
r34king's Avatar
r34king
A/c drain hose. Its supposed to do that. Looks like water not coolant
Old Mar 23, 2013 | 11:40 AM
jerrylee's Avatar
jerrylee
Wow is it really? Oy, thanks for putting my mind at ease about that, but that complicates things since at the end of my test drive last night, it was overheating a bit. Siiiiiigh. Gotta figure out why it's overheating.
Old Mar 23, 2013 | 11:44 AM
fr0mmagna's Avatar
fr0mmagna
When you bled the system did you have the heater on ??
Old Mar 23, 2013 | 11:54 AM
ZippyNH's Avatar
ZippyNH
It can take 2 or 3 bleeds to get it right....the bubbles can be a pain to get out.
Generally i find it takes a bunch of extra coolant, BOTH bleed ports (i think on a base)alternating open, a couple drives to get the air out....then hose the bay down to get rid of the dripped coolant/smell.
Both the cooper and the s can be a pain to bleed....even pro's dealers have issues, and sometimes use vacume bleeders....
Old Mar 23, 2013 | 12:12 PM
jerrylee's Avatar
jerrylee
Yeah, I had read a bunch before I did it and one thing I saw was to make sure the heater was on, so no problems there. However, I did only bleed it the one time, so maybe that's all it is, a little air sneaking in there. That would be a huge relief! I'll bleed it a bit more this evening and see where it's at.
When I am topping it off, should I just be using the expansion tank or should I be going right through the filler cap? My concern at this point is that I filled it yesterday, a little air got in, but I'm going to open up the filler cap and whoosh, more air, kinda defeating my progress.
Cereall
Sep 5, 2019 06:05 PM
Khai
Feb 6, 2017 09:24 AM
KrisMiss
Jan 3, 2016 02:02 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
