R56 2009 Cooper S - Need an engine. :(
Old Mar 14, 2013 | 02:43 PM
solmisate's Avatar
solmisate
So it turns out that a camshaft bolt broke off, destroying the timing chain and as such, my engine.
I need a new engine. Where's the best place to get one? I'm not made of money so cost is a huge factor... but if you guys can point me in the right direction I would appreciate it.
-David
(Now-dead) R56 2009 Cooper S, 68k miles.
Old Mar 14, 2013 | 04:33 PM
Paul's Avatar
Paul
try http://car-part.com/
or
http://www.lkqcorp.com/
Old Mar 14, 2013 | 06:21 PM
Braminator's Avatar
Braminator
http://www.jmturbocoopers.com/Mini-E...d-Exhaust.html
Old Mar 14, 2013 | 06:36 PM
JAB 67's Avatar
JAB 67
Or Way Motors.
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We can sell you a brand new engine for less than $4k, which has a 2yr warranty and includes a new water pump, oil filter housing,vacuum pump,and thermostat.
Old Mar 15, 2013 | 06:33 AM
solmisate's Avatar
solmisate
Interesting. I called you guys yesterday afternoon and I was told that you didn't have an engine for my car, nor could you get one. Was this information incorrect?
Old Mar 15, 2013 | 07:22 AM
furry's Avatar
furry
scary, hope you find a replacement. I take it timing chain/tensioner were never repaired under warranty?
Old Mar 15, 2013 | 07:58 AM
solmisate's Avatar
solmisate
I picked it up used after the warranty had expired, but it doesn't look like it. That being said, the mechanic I took it to said that it wasn't the tensioner that failed, it was the bolt in the cam shaft that holds on the timing wheel. Just total bad luck I guess. :(
Does make me think, though... how many MINIs are flying around out there with drivers that never check these forums and have no idea about the tensioner/chain issue? They are driving ticking time bombs. I only found out about that when the car died the other day and I started doing some research.
Old Mar 15, 2013 | 08:18 AM
6000pounds's Avatar
6000pounds
I can't believe people are selling these 1.6 sohc motors for over 4k.
I would look at putting in a honda K20 motor before i spend close to 5k for the little engine that could :/
Good luck OP
09R56
Nov 16, 2022 10:49 AM
Sexual Chocolate
Mar 31, 2019 08:02 PM
marendt428
Nov 14, 2015 10:03 AM
xpunisherx
Aug 10, 2015 10:50 PM
marendt428
Aug 8, 2015 04:44 AM
