strange sound any ideas? update
Old Mar 26, 2004 | 06:38 AM
mpower's Avatar
mpower
There is this strange sound coming from the front of the car when decelerating to a stop which continues for about 2 seconds even after the rpm's fall back to idle. It sounds like a high pitched elephant. Although not very loud it is noticable over the magnaflow which says something. Any ideas what this could be.
_________________
2003 MCS- DS on black, xenons, alta CAI, magnaflow, more to come.
Old Mar 26, 2004 | 06:48 AM
chrisneal's Avatar
chrisneal
Sorry to ask the obvious, but you're sure it's not the power steering, right? You've had your car for a while?
Old Mar 26, 2004 | 06:51 AM
Helix13mini's Avatar
Helix13mini
Your PCV valve has failed. It's a really common fault for MCSs and is a quick warranty fix. It's not immediately dangerous to your car (but keep an eye on your oil level). You can confirm it by squeezing the rubber hose that comes out from your valve cover, just next to the MINI logo (on the top of your engine). If it is soft and oily, I'm right. Let us know. -Eric
dominicminicoopers's Avatar
dominicminicoopers
I know this one!!!
PCV hose needs replaced. Some people say when the hose is bad that the PCV valve also needs to be replaced as well.
Old Mar 26, 2004 | 07:29 AM
CooperBeagle's Avatar
CooperBeagle
Oooh! Oooh! Call on me! I know this one too!
I just put a temporary clamp on my PCV hose,
works like a charm. At least until I get to the
dealer.
Godspeed.
Old Mar 26, 2004 | 07:30 AM
dominicminicoopers
Oh, you're sooo smart!
Old Mar 26, 2004 | 07:37 AM
mpower's Avatar
mpower
thanks guys I will check those hose later today and report back.
Old Mar 26, 2004 | 08:02 AM
10851CS's Avatar
10851CS
Just like in school -- when I know the answer the teacher calls on someone else.
Earl
Old Mar 26, 2004 | 08:42 AM
Helix13mini
and I'm the smartypants knowitall.
There's a first for everything.
Hey teach, want an apple.
Old Mar 26, 2004 | 08:46 AM
dominicminicoopers
Old Mar 26, 2004 | 09:08 AM
mpower's Avatar
mpower
I just checked the soft rubber hose,. Question: is there supposed to be a clamp because mine did not have one and I was able to just slip it off, it was a little oily but not dramatic. Any advice
Old Mar 27, 2004 | 04:54 AM
mikeoconnor1's Avatar
mikeoconnor1
Had mine replaced yesterday by the dealer. They know all about the problem. My advice is to let them fix it.
Old Mar 27, 2004 | 07:09 AM
dominicminicoopers
Mike, did they just replace the tube or did they do anything else?
Old Mar 27, 2004 | 07:30 AM
mikeoconnor1
On the paperwork I got back with the car, it shows 2 filters and the hose being replaced. Since the car had it's 25K service done, I was assuming the 2 filters were the air and oil. It doesn't mention a PCV valve, so I guess that part was OK.
The mechanic knew right away what the problem was when I dropped it off on Thursday, so this must be a common problem.
JHolland
Aug 24, 2015 07:04 AM
missinmyjeep
Aug 22, 2015 07:13 PM
Herleman
Aug 16, 2015 06:41 PM
