Rotating crankshaft
Old Mar 24, 2004 | 07:32 PM
Jonauto's Avatar
Jonauto
one of the steps for removing the head call for you to rotate the crankshaft so that the mark on the camshaft sprocket is at 12 o'clock.... how the heck do i rotate the crank..... i tryed using a large torque wrench turned up to 120 ft. pounds.... didnt move..... tryed jacking the car up and me and someone else try as hard as we could to turn the engine with the wheels.... no luck
should i try to the torque wrench with more power (i was afraid id break something) or do something else?
Old Mar 24, 2004 | 07:38 PM
MiniPilo's Avatar
MiniPilo
Do you still have the spark plugs in? It might help to take them out and release the pressure of the Combustion chamber.
Old Mar 24, 2004 | 07:42 PM
Jonauto's Avatar
Jonauto
im gunna go do that right now
thanks
Old Mar 24, 2004 | 07:43 PM
Trippy's Avatar
Trippy
And make sure the transmission is in neutral.
Old Mar 24, 2004 | 07:45 PM
dave's Avatar
dave
pug poo picker-upper
I'm going to bet that's the issue.
Old Mar 24, 2004 | 08:04 PM
pocketrocketowner's Avatar
pocketrocketowner
Either that or the engine is so blown itis seized solid.......
Old Mar 24, 2004 | 08:39 PM
Jonauto's Avatar
Jonauto
yes it was in neutral......
still didnt work, i think the one cylinder that has had the valves on it open for who knows how long is rusted shut..... bummer..... we just tried pushing it up the driveway (steep hill), letting it go, and putting it in gear when it got up to speed.... and the wheels just locked up and the engine didnt turn at all..
Old Mar 25, 2004 | 09:29 AM
holdenontoit's Avatar
holdenontoit
pour a 1/2 cup of marvel mystery oil into each spark plug hole and wail 24 hours and try again.If this doesn't work,you have a seriously seized engine on your hands.Maybe you should change the name of the project to"shake and baked"
Old Mar 25, 2004 | 03:04 PM
Jonauto's Avatar
Jonauto
where do u get this mystery oil?
Old Mar 25, 2004 | 03:15 PM
dominicminicoopers's Avatar
dominicminicoopers
Automotive shops will cary it. Comes in a red colored bottle if I recall correctly...
Old Mar 25, 2004 | 03:17 PM
dominicminicoopers
Check this out: http://www.tooldesk.com/cgi-bin/webp...amp;key=marvel
Old Mar 25, 2004 | 03:28 PM
caddman's Avatar
caddman
Another option is pull the head and take a look, the timing can be worked out later, granted the intruction method is easier, but there are more than one way to skin a cat if you know what i mean....... hope its not seized.....
Old Mar 25, 2004 | 03:39 PM
911Fan's Avatar
911Fan
I guess "Crispy" means that this engine was in a fire.
If so, you probably have baked on varnish (from cooked oil) all over the engine internals.
I don't think you'll have much luck with the Marvel because you won't be able to put it on the crankshaft, internal cylinder walls, etc. without a lot of dismantling.
But I guess there's no harm trying.
Old Mar 25, 2004 | 05:44 PM
Jonauto's Avatar
Jonauto
i got the head off and it looks pretty icky in there.... ill put some pics up on the web so check my site later tonight or tomorrow morning if u want to see it
Old Mar 25, 2004 | 05:48 PM
Trippy's Avatar
Trippy
Please do post pictures.
I would go with the WD-40 or "miracle-oil" on top of the pistons, wait a while,
and give each of them a quick pound with a 4x4 block. Not too hard, but a good
solid rap and you might get turning again.
Engines are damn tough beasties.
Old Mar 25, 2004 | 06:22 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Your best bet would be to pull the head and investigate what might have happened in the cylinder. Molten plastic could have made it's way into the cylinders. If the fire was put out with water, the melted intake might have been open and allowed water to enter the cylinder and sit, rusting the engine. This is not a 'death sentence' for your engine as such, because it can be freed with light oil and movement, then cleaned up with a cylinder hone and compressed air with the piston at BDC. Washing down the cleaned cylinders with WD 40 and gently rocking the engine will help clear the area just above the compression rings. Thoroughly wipe up then lube the cylinder walls with motor oil and spin the engine over several times. Wipe up anything you might find after doing this then re-oil the cylinders.
While you have the head off it would be a good idea to possibly have it machined flat to correct for any warpage, and giving all the bearing journals and rockers a thorough oiling will make for a happy top end. An engine fire tends to bake out the oil from the various moving parts.
I have worked on several 'crispyfied' engines such as what you are attempting, and you would be surprised at how much you can bake an engine without too much internal damage.
Old Mar 25, 2004 | 08:03 PM
Jonauto's Avatar
Jonauto
Pics of the head removal can be seen HERE
Old Mar 25, 2004 | 08:08 PM
Trippy's Avatar
Trippy
Oh Poo.
Nothing a little scotch-brite won't take care of.
Give everything a good oil-soak and hit it with some steel-wool,
a wire brush and scotch-brite pads. Not the ones with sand I would say.
Vacuum out all the crap, give the pistons a whack, and I'll predict you'll have
some crank motion in a day or so.
Old Mar 26, 2004 | 06:48 PM
MiniPilo's Avatar
MiniPilo
Hey.. I think that there is a JCW Engine on Ebay.. that might be your best bet looking at this engine. Good Luck
Old Mar 26, 2004 | 09:16 PM
Jonauto's Avatar
Jonauto
yeah, i saw that too..... i wish i had that much money right now.... i may be able to afford a regular S
Old Mar 26, 2004 | 10:09 PM
Jonauto's Avatar
Jonauto
ok, one more quick question...... how should i be trying to rotate the crank?
Old Mar 26, 2004 | 10:34 PM
911Fan's Avatar
911Fan
I think you should soften up all the gunk before attempting to turn the crank. Otherwise, you might end up breaking rings, scoring cylinder walls, or causing some other unnecessary damage if you forcibly turn the crank.
You'll need to dismantle the block anyway to replace things like gaskets. So why not remove the block from the vehicle now. Then you can remove the oil pan and expose the inside of the block.
Soaking the head and the opened block in Marvel for a few days should soften things up. btw, I think you can buy Marvel by the gallon...
Have you done any engine rebuilding before?
Old Mar 26, 2004 | 11:31 PM
Jonauto's Avatar
Jonauto
i just drained the oil and im gunna start on that tomorrow.... is it possible to get the block out without removing the transmition?
And this is my first engine to rebuild....
Old Mar 27, 2004 | 01:28 AM
binkysmini's Avatar
binkysmini
Jon,
I know 4500 is not in the budget for the Works motor on eBay, but here is a non-S motor now listed. Starting bid 300. But needs to be shipped from GA.
ebay motor
May be worth a look.
More power to you, that's quite a project you've undertaken there.
Cheers!
911Fan's Avatar
911Fan
" is it possible to get the block out without removing the transmition?"
Don't know for sure but I doubt it. Besides, I think you're going to want to remove the transmission just to visually check it over and to assure yourself that it wasn't affected by the fire.
Have you looked for a service manual for this engine yet? There might be some third-party books available by now.
If nothing else, you should make friends with the parts guys at the nearest MINI dealer. I'm sure if you tell them what you're doing, they'll be very helpful. They might even be able to give you access to an official service manual (it's probably on a CD).
You've taken on quite a project! It'll be a great learning experience for you. It's nice of you to give the rest of us a chance to follow along on your website.
patsum
26
May 29, 2021 06:29 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
lifeofjenn
19
Sep 24, 2015 11:01 AM
Norton70
Sep 24, 2015 06:31 AM
Sep 3, 2015 02:06 PM
