Identify this frayed hose
Old Sep 1, 2012 | 07:25 PM
PenelopeG3's Avatar
PenelopeG3
Car = 2006 Mini Cooper S w/ Automatic trans
Was peeking around underhood and noticed this frayed hose that is pulled tight. Seems like it is dangerously tight and will probably split.
Anyone know what hose this is?
Thanks.
Top level view:
Close up:
Old Sep 1, 2012 | 08:16 PM
ERIK06MCS's Avatar
ERIK06MCS
Not very familiar with the automatics but perhaps its not a hose at all and rather the shift cable going to your p-R-N-D-L lever on the tranny itself. Grab the line with engine off/cold and have someone hop in the car and run the shifter through p-n-r-d etc and see if you feel it. Obviously engine off and cold so you don't burn yourself. But based off how low that cable is and on tranny side I'd bet its for the trans.
Old Sep 1, 2012 | 08:25 PM
ACEkraut11's Avatar
ACEkraut11
Which begs the question, what caused the damage?
Old Sep 1, 2012 | 08:39 PM
ERIK06MCS's Avatar
ERIK06MCS
Obviously it looked like it chafed against the ribbed silver cylinder. Not sure if that's MINI's version of a tranny cooler, looks similar to the oil cooler with its ribbed fins on the outside.
Waiting from verdict from original poster though..
Old Sep 1, 2012 | 08:42 PM
ERIK06MCS's Avatar
ERIK06MCS
silver thing looks like tranny oil cooler:
http://www.realoem.com/bmw/showparts...64&hg=24&fg=15
Cable indeed looks like auto trans shift cable:
http://www.realoem.com/bmw/showparts...10&hg=25&fg=20
Old Sep 1, 2012 | 10:09 PM
PenelopeG3's Avatar
PenelopeG3
It looks like it goes into the top of the tranny. I don't have a second person around so can't shift through to feel if the cable moves.
The trans has been in/out of the car about 4 times when the dealer replaced the oil pan seal instead of correctly diagnosing the issue as the O-ring at the rear of the block. Given their terrible ability to diagnose, they probably screwed this up on the re-install. That line doesn't seem to be able to be routed differently so I don't understand why it would be so tense.
I hate dealer$...
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
GAT
Oct 4, 2015 07:27 PM
fkrowland
Sep 30, 2015 10:30 AM
point665
Sep 29, 2015 12:41 PM
daviday
Sep 25, 2015 01:31 AM
