Stripped Sway Bar threads for Sway Bar Bushing
Old Aug 13, 2012 | 10:51 PM
NintenTom's Avatar
NintenTom
Hey guys. So I was reinstalling my Alta 22mm RSB this weekend and the hole closer to the front of the car on the driver's side seems to be stripped. I'm thinking it got crossthreaded or something during my last install (doh!). So now I currently only have 3 of the 4 screws in right now (includes driver/passenger sides). Is there a fix for this or is it safe enough to have only 3/4 screws in. I have a feeling it won't be safe when I go tracking though with the current setup.
Old Aug 14, 2012 | 05:46 AM
J&M'sMini's Avatar
J&M'sMini
Those bolts strip out very easy.
I recently installed a new sway bar..overtorqued..and stripped it out
..easy quick fix, get a bolt with a nut that will fit through, is what I did.
Did some hard driving last weekend on back country roads..and all is fine.
..definitely don't want to just not have a bolt in there!
Old Aug 14, 2012 | 06:19 AM
slinger688's Avatar
slinger688
You can use helicoil on the sway bar attachment bolts.
Do not go to the track with that suspension. It the bolt backs out during one of your runs, you will be in serious trouble with oversteer.
Old Aug 14, 2012 | 10:08 AM
NintenTom's Avatar
NintenTom
I recently installed a new sway bar..overtorqued..and stripped it :
Do you remember what size bolt and length etc. you purchased for the bolt/nut fix? Thanks!
Old Aug 14, 2012 | 11:55 AM
J&M'sMini's Avatar
J&M'sMini
..don't know size/lenge of bolt & nut, just found something that I happened to have around. ...is good to have an assortment of extra nuts/bolts like that..just in case.
I'm gonna also look into what slinger688 suggested (helicoil) have not used before..but definitely seems like something good to have in the garage for these sorta things
slinger - I searched briefly on the helicoil, is there a certain vendor you recommend...or a kit/pack that you recommend to order?
J
Old Aug 14, 2012 | 01:50 PM
NintenTom's Avatar
NintenTom
J
That's basically why I was asking the exact size. Helicoil kits are based on the specific bolt size/pitch.
Old Aug 17, 2012 | 08:13 PM
slinger688's Avatar
slinger688
J
Pm eddie07s. He knows Enough to be an expert on Helicoils.
Old Apr 3, 2020 | 08:20 AM
MikeMJCW's Avatar
MikeMJCW
Oops wrong thread.
Old Aug 9, 2020 | 05:51 PM
TheGeekGuy's Avatar
TheGeekGuy
No text
studio47
Jun 13, 2019 01:53 PM
jtack
Suspension
Apr 1, 2008 11:53 AM
Darkness
Suspension
Apr 14, 2007 09:18 PM
DK23
Dec 17, 2006 12:19 PM
SB
Suspension
Oct 11, 2006 10:24 PM
