chances of good will repair
Old May 20, 2012 | 01:07 PM
  #51
drsimmons's Avatar
drsimmons
Looks really clean from the pics.
54K and the $$$'s isn't bad.
Like I said, I think anyway, mine had 57K on it when I bought it.
Now it has almost 67K.
Old May 20, 2012 | 02:55 PM
  #52
Minishirk's Avatar
Minishirk
Yeah I will be piling on miles quickly...Sometimes I got a 70miles drive to work one way..not every day but there will be weeks where I go to Philly every day....It is certified by this dealer, I think I would like to take it to a Mini dealer first though...just in case.
Old May 21, 2012 | 01:52 PM
  #53
Minishirk's Avatar
Minishirk
Car has an extended warranty to 100k miles or 10/2013. sweet!
Old May 21, 2012 | 03:38 PM
  #54
drsimmons's Avatar
drsimmons
Sounds like you're covered.
Again, watch the oil level. Check it weekly.
If you do hear a sound like rocks bouncing around in the
upper passenger side of the engine, get it in ASAP.
Old May 21, 2012 | 04:02 PM
  #55
Minishirk's Avatar
Minishirk
Thanks yet again. When I get it I will post pictures Did your car come with those rims?
Old May 21, 2012 | 04:19 PM
  #56
drsimmons's Avatar
drsimmons
Nope. Car was completely stock when I bought it. Here's what I've done.
* Megan Racing Coilovers
* Enkei WMD 16" wheels
* Yokohoma s-drive summer tires
* Oil catch can and boost tap
* NM CAI
* H-sport 19mm rear sway bar
* MiniMania alloy front strut brace
* NM torque arm mount inserts
* H-sport rear camber links
* Black jack mirror cover, side skuttles, door handle covers
* NM turbo heat shield
* NM turbo line heat shield
I think that's it.
Love it.
Really handles like a modified go cart now.
Old May 21, 2012 | 05:55 PM
  #57
Minishirk's Avatar
Minishirk
haha it handles like that to begin with...sorry this thread got a bit off topic...
Old May 21, 2012 | 06:10 PM
  #58
drsimmons's Avatar
drsimmons
In all seriousness, a little suspension modification and you'll know what I mean. Alot of folks go for more power but a Mini will never be a fast car off the line. But, take it through twisties, curves, and all and it's tops.
If yours doesn't have an oil catch can and boost tap installed already, that is the one thing I'd go for. It's not suspension but it'll help keep your intake cleaner and reduce the amount of carbon buildup.
Old May 22, 2012 | 03:51 AM
  #59
Minishirk's Avatar
Minishirk
Yep, already have that planned out. Install looks very easy as well, does it really matter what style catch can you get? I am assuming the difference between a 150 billet one vs a ebay special is the build quality.
Old May 22, 2012 | 04:33 AM
  #60
drsimmons's Avatar
drsimmons
I'm only familiar with the BSH which I know has baffles in it which is a good thing. Also, it has a lower drain plug and if you want to siphon it out it has a top hole with a little dip stick. The dip stick is nice for checking the level in it.
Kinda costly but well worth it.
Kimolaoha
Dec 5, 2020 09:32 PM
woodstudio
Mar 15, 2020 08:28 AM
Steeroidz
Aug 29, 2018 07:41 AM
Getrieben
Aug 17, 2016 06:32 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
