R56 Headlight Problem, check engine light
Old Jan 31, 2012 | 07:31 PM
pingpongchingchong's Avatar
pingpongchingchong
My 2007 R56 Mini Cooper check engine light comes on when I start the car. I am unable to make the Xenon high beam headlights work when I push the stalk forward. However, the high beam flash to pass works just fine when I pull the stalk back toward me. Do I have a bad headlight relay? How can I fix this?
Thanks.
Old Feb 1, 2012 | 04:30 AM
yetti96's Avatar
yetti96
Can you get the code pulled and start there? Dumb question but are the xenon headlights OEM and original to the car?
Old Feb 1, 2012 | 06:22 AM
richardsperry's Avatar
richardsperry
1.) buy a Scangauge2 and see what te MIL (ce light) is about.
2.) Probably need a new trun signal stalk. (if the lights are stock Bixenon, and they work when you flash to pass)
Old Feb 1, 2012 | 07:25 AM
pingpongchingchong
I have OEM bi xenon lights. I am going to bring the car the the stealer tomorrow, since I don't have time to fix.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
