Lower Radiator Hose
Old Jan 24, 2012 | 10:44 AM
WoodyWold's Avatar
WoodyWold
Lower Radiator Hose
Hi,
I had the brackets that hold up the lower radiator hose on my 2010 Clubman S break off and cause the radiator hose to drop low, which in turn caused a hole to rub off on the bottom of the hose and all of the fluid to drain out on the highway.
My dealer is now claiming I "hit something" that damages the hose, which I am certain I did not. I have photos of the supposed "damage" to the underside of the car, but what they show is basic light scraping on the underside of a low-clearance car.
I see some other posters on here with similar issues with erosion of that hose, and now I am wondering if this is a common problem or design defect. It does not look like there is much protection for the hose and brackets, though the assembly is very close to the bottom of the car and the road.
Thanks all,
Woody.
Old Jan 24, 2012 | 10:57 AM
WoodyWold's Avatar
WoodyWold
Lower Radiator Hose
Here is a photo of the damage
Old Jan 24, 2012 | 12:59 PM
Dodgy's Avatar
Dodgy
Hi Woody--I'm one of those you mentioned. My wife fortunately spotted the drooping hose as I pulled up our driveway (on a hill) before anything leaked. In the photo it looks like the vertical plastic has a small tear? Mine didn't suffer that, but most of the plastic clips did break, allowing the hose to fall lower. The dealership replaced the clips for me free of charge, and did say it was a poor design.
Sounds like you just need to replace the hose, clips, and coolant? Engine didn't overheat or anything catastrophic, did it?
Old Jan 24, 2012 | 01:19 PM
WoodyWold's Avatar
WoodyWold
Thanks Dodgy,
Can you tell me which Dealership you used because mine is fighting me on it.
And yes my car overheated...that is how I found out the hose had dropped down. Not sure if that caused any additional damage yet.
Woody
Old Jan 24, 2012 | 06:23 PM
Benibiker's Avatar
Benibiker
It doesn't help that your spoiler looks damaged like you hit something so I can see why your dealer is fighting it. I agree the hose should be a little more protected though.
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
smdmini
Oct 7, 2019 06:05 AM
makg
Sep 10, 2015 11:59 AM
eliseo1981
Sep 4, 2015 02:33 PM
