Where is coolant bleeder screw?
Old Jan 21, 2012 | 02:00 PM
klricks's Avatar
klricks
I am looking for the bleed screw. I have the '07-'11 Bentley manual but it does not have a picture. The TIS has picture but it's not clear.
I have searched forums but they are mostly 1st gen.
Problem I am having is heater goes cold at each stoplight.
I have '10 Justa Clubman with manual heater controls. Coolant in reservoir is up to max line.
Would like a photo if possible.
Old Jan 21, 2012 | 03:35 PM
gregsmini's Avatar
gregsmini
Check this, page two shows the picture:Draining and adding coolant.pdf
Old Jan 21, 2012 | 04:07 PM
klricks's Avatar
klricks
Originally Posted by gregsmini
Check this, page two shows the picture:Attachment 57861
I have seen that photo in other threads but it does not look anything like what my engine looks like.
Old Jan 21, 2012 | 04:34 PM
klricks's Avatar
klricks
OK I found it. It is fairly large cap like thing with a (+) slot for a straight blade screwdriver. Does not even look like a normal screw or bolt head.
The pdf was for N14 engine and I have N12.
Went back to my TIS which is still not accurate because the last model the ebay TIS covers is '08 and I have '10.
Old Feb 27, 2015 | 03:13 PM
wsalopek's Avatar
wsalopek
How about a picture? I can't find it either (2009 R56, non-S)
Old Feb 27, 2015 | 03:21 PM
05r50's Avatar
05r50
It's a large black plastic screw. It blend in well. Straight down from the top between the hoses. Look for a large +.
Don't unscrew too far or it falls out and then can be hard to find.
Old Feb 27, 2015 | 10:11 PM
wsalopek's Avatar
wsalopek
Near the thermostat? Right side of engine? I have looked around there...do I need to take something apart to see it?
Thanks...
Old Feb 28, 2015 | 03:59 AM
JAB 67's Avatar
JAB 67
If it is not obvious, the previous owner may have replaced the upper coolant hose with an aftermarket one, e.g. silicone, without the bleeder.
Old Feb 28, 2015 | 10:16 AM
05r50's Avatar
05r50
Located on top of the thermostat housing
Old Oct 5, 2015 | 12:28 PM
timski's Avatar
timski
Nope. It is 100% not there. I have a 2011 JCW and it had the thermostat housing replaced in 2011. I am looking at a pic of a thermostat housing online. I see the coolant temp sensor and bleeder screw. On my car I see some kinda of modified temp sensor and exactly where the bleeder screw should be - nothing. Maybe this was a service bulletin or an updated part? Any help would be great because when I refilled the system only took in about 32 ounces of mixture and not a drop more. Ran the car with heat on for a few minutes hoping the thermostat would open and suck it in - nope. Don't want to overheat the car. Any suggestions?
Old Oct 5, 2015 | 12:34 PM
timski's Avatar
timski
I have what looks sort of like a bleeder screw but it's actually the temp sensor because it has 2 wires coming out of it. Weird.
Old Oct 5, 2015 | 07:00 PM
timski's Avatar
timski
Ok. The N18 bleed screws are integrated into the temp sensor. Weird turning a plastic bleed screw with temp sensor wires attached to it. Never seen such a thing. By the way I have a 2011 JCW with a N14 engine apparently with an updated t stat housing similar to the N18 engine.
Old Oct 7, 2015 | 08:23 AM
HaveATank's Avatar
HaveATank
The screw is right above the connector. I have an N18. How can you tell if your have an upgraded T stat?
Old Oct 7, 2015 | 09:13 AM
timski's Avatar
timski
I have no idea how to determine if one has an updated/upgraded t stat housing.
The MINI stealership looked up the p/n of my t stat housing changed by the previous owner - and when I googled that p/n a picture of the old t stat housing shows up - which does not match what is on my car. There must have been some upgrade or service bulletin done to my car. I finally found the bleed screw so I'm all good.
Old Oct 9, 2015 | 07:21 AM
tag1260's Avatar
tag1260
Might be a dumb question but does the bleeder screw all the way out or is there a stop on it? In other word, can you screw up and screw the screw all the way out until it is completely out or will it stay in the hole?
Old Oct 9, 2015 | 06:31 PM
05r50's Avatar
05r50
Don't screw it out all the way.
It will fall and you won't find it. Just loosen and wait tail it starts burping coolant then tighten.
Old Oct 10, 2015 | 11:12 AM
tag1260's Avatar
tag1260
Thanks. That's what I thought. Just wasn't sure.
Old Mar 16, 2016 | 04:51 PM
tragedybysyntax's Avatar
tragedybysyntax
I can't find my bleed valve either.
2008 r56
Old Jun 4, 2016 | 06:20 PM
greentrees's Avatar
greentrees
I turned mine out three full turns. Maybe 3 and a half. Fluid came out and I screwed it back in. It doesn't seem to tighten fully and seems to keep going around. Maybe I turned it out too far? and need to thread it properly?
Old Oct 23, 2016 | 04:06 PM
Longtrout707's Avatar
Longtrout707
R56 2007 mini S bleeder screw
I recently bled the cooling system on my R56 2007 mini S and had a difficult time locating the bleeder screw. Although there were others who were able to describe its location, there weren't any detailed photos of my model online so I thought I'd post my photos in hopes that it may help someone in the future.
When looking at the driver side of the engine bay, the bleeder screw is in line with the spark plugs (specifically the region to the right of the 4th spark plug), and 3 inches below the plane of the spark plugs (the region will be dark making it difficult to see the already black screw, but it's reachable). 2nd photo shows a magnified shot with a flathead in the slotted bleeder screw for reference.
Attached Thumbnails Where is coolant bleeder screw?-img_5486.jpg   Where is coolant bleeder screw?-img_5484.jpg
Old Oct 23, 2016 | 06:29 PM
yesti's Avatar
yesti
My 2012 S did not come stock with a bleeder screw. The new thermostat did have one. Surprisingly bleeding the system was very easy, didn't need the screw, I have heat and engine runs at correct temperature. Now changing the thermo, h2o pump and water pipe was not fun. Thanks for the incredible design whoever did that.
Old Dec 23, 2016 | 04:37 PM
Frixos's Avatar
Frixos
Thank you so much; this was very helpful. It only took me 10 seconds to find it thanks to you.
I'm curious, what is the purpose of this screw? It is not referenced in Pelican Parts guide:
http://www.pelicanparts.com/techarti...ing_System.htm
Old Dec 23, 2016 | 06:08 PM
AZdsrt's Avatar
AZdsrt
Allows you to remove air from the system after replacement of water pump, thermostat housing, coolant, etc...
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
Cruzer214
Oct 11, 2015 07:45 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
point665
Sep 29, 2015 12:41 PM
silence2-38554
Sep 28, 2015 12:19 PM
