Clutch
Old Dec 8, 2011 | 02:57 PM
flower132's Avatar
flower132
Clutch
Hi,
The clutch on my MINI 03(not an S) needs to be replaced. The dealership quote is between $1,400 to $1,800. Anyone in this forum has experience changing the clutch? Thank you.
Flor
Old Dec 9, 2011 | 08:55 AM
proximo's Avatar
proximo
That's pretty spot on for the parts alone. If that's including their time, take them up on it.
Clutches are relatively easy (if you have the tools and a transmission jack). It's just time consuming (about a half days work with a minimum time around 3.5 hours). There are a few videos on YouTube about changing a clutch that work generally with any vehicle, but you might source the Bentley manual to get explicit instructions.
Old Dec 9, 2011 | 09:21 AM
flower132's Avatar
flower132
Clutch
Hi Proximo,
That price includes labor and parts. Thank you for your response .
Flor
Old Dec 12, 2011 | 11:18 PM
MiniDeLux's Avatar
MiniDeLux
I had mine changed out 2 weeks ago. When you say the "clutch" needs to be changed does that also include the flywheel? How many kms on the car? Usually when they open the car up, they inspect the flywheel for hot spots. This will be your case if the clutch has actually been slipping.
Correct me if I'm wrong but in the 03 non-S I think it's a twin mass flywheel so if damaged it will require replacement as it can't be resurfaced. Not sure if that is included in your quote or not. The single mass flywheels can be resurfaced so it's cheaper.
For the record, my clutch and flyhweel change put me at about €1900. If your quote doesn't include the flywheel, you're looking at about 600+ additional for the cost of the flywheel.
Old Dec 13, 2011 | 12:35 PM
flower132's Avatar
flower132
Clutch
Hi,
Thank you for your response . You are absolutely right. My MINI has twin mass flywheel. I was told if they do not have to replace the flywheels the price will be $1,400 but if they have to replace them the cost is going to be $1,800. My car has approx 86,000 miles(I believe in kms is 138403.584). Wow you were charge $2,506.79 US Dollars that is a significant amount. Both prices includes labor and parts.
What year is your MINI?
Flower
Old Dec 13, 2011 | 11:08 PM
MiniDeLux's Avatar
MiniDeLux
Originally Posted by flower132
Hi,
Flower
My Mini is a 2009 Clubman (75,000km). It has the diesel engine.
Don't go too much by the exchange rate to compare costs. The price you were quoted ($1800) sounds about right for work done by the dealership. If I were you, I'd budget for the flywheel change. In any case, since you have high mileage, it would be good for you to change the flywheel now otherwise in the not too distant future, you'll just have to pay to open up the car again and pay a 2nd time for all the labour. The flywheel is easy to change once the clutch is out for replacement. Labour cost is minimal, it's just the parts cost of a new flywheel.
Unfortunately, I am discovering that once the mileage accumulates on these cars, they can be rather expensive to maintain. A cheaper option would be to go to an independent garage, but there you don't get the same coverage as with the dealership.
Enjoy the new clutch I think you'll see a big difference in driving characteristics after the service.
Old Dec 14, 2011 | 08:22 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
non S cars don't have a dual mass flywheel FYI.
$1400 seems to be cheap for a dealer, I know are price is closer to $1000
Old Dec 23, 2011 | 12:09 PM
Mynewt's Avatar
Mynewt
(...) if they do not have to replace the flywheels the price will be $1,400 but if they have to replace them the cost is going to be $1,800. My car has approx 86,000 miles(I believe in kms is 138403.584). Wow you were charge $2,506.79 US Dollars that is a significant amount.
I'm facing this operation on my 2003 R50. It has 83,000 miles (about 134,000km). The clutch is working well, it's just that the throwout bearing has been rattling for the last 20,000 miles or-so.
My mechanic (an independent Merc/BMW/Porche/Audi/Mini specialist) said it would be roughly $2,000 U.S. without the flywheel and $2,500 with. Using all OEM parts at $80/hr labor.
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
