Turbo Oil Pipe Leak
Old Sep 10, 2016 | 12:10 PM
  #26
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Originally Posted by j.p.francis@wanadoo.fr
Shoot! In & out Mini Cooper S turbo oil line - YouTube
Bad design
While this pipe is NOT Re-usable once taken off, that articulation you demonstrate in that video of that joint IS Perfectly NORMAL...
Carry on !
Old Sep 10, 2016 | 11:24 PM
  #27
j.p.francis@wanadoo.fr's Avatar
G RAY! This makes my day! thanks the video was found on you tube
Just to confirm: the tube moves in an out But the O Ring keeps the seal. &The ridge on the pipe which is on the inner side of the O Ring seat prevents the tube from coming out completely ? The loose play tightens up with oil pressure?
Thanks very much
John
Old Sep 11, 2016 | 01:50 AM
  #28
Nuts , I am leaking: Oil stops leaking when the tube is pressed in , when it is not being pressed in, it leaks
Question:When pressed in ,is the oil being blocked/starving the turbo OR is the just sealing some how?
Here is a photo: http://screencast.com/t/D4G8d8jqycIK
What side is the pipe ridge on : A or B ?
TIA
Old Sep 12, 2016 | 07:46 AM
  #29
Lex2008's Avatar
Lex2008
The pipe end fitting has to be pulled taught for the o-ring to seal.
Old Sep 12, 2016 | 12:36 PM
  #30
Ok the ridge is on side A http://screencast.com/t/D4G8d8jqycIK
Old Sep 19, 2016 | 09:28 AM
  #31
-=gRaY rAvEn=-
Moderator
Does anyone have an idea of what the oil pressure is in the pipe? High , medium or low answer would work
TIA
Most engine oil pressure is 35 - 40, not sure what it is exactly for that line however.
If you trying to "reuse" that oil feed line Francis, they are not designed to be reinstalled once removed.
A new line, new crush washers (x4) and new banjo bolts (x2) is a requirement, never a recommendation. They will always leak if this procedure is not followed. They typically need replacing due to leaks every 60-70k miles as do oil filter housing gaskets, so best to do them all same time.
Old Sep 19, 2016 | 11:13 AM
  #32
Thanks gray, it is in the shop now!
Old Sep 21, 2016 | 08:13 AM
  #33
Lex2008's Avatar
Lex2008
Gray R,
Not sure I agree about the oil line not being reusable. Its ideal to use new copper washers but those can get recrushed too. Banjo bolts can be reused.
The oil filter housing...ya man that's a messy job. I did a write up on that crappy endeavor.
Old Sep 21, 2016 | 08:50 AM
  #34
I got it done in the shop ......I had clamped it in place with a plumbing clamp and it was fine , no leaking at all, but I don't want to start leaving hacks like that in place. I reinstalled my RaceChip Pro and I am really loving the car! Just super on the twisty back roads in the South of France.
Old Sep 21, 2016 | 01:01 PM
  #35
gcaspelich's Avatar
gcaspelich
More information found for the oil line leak at:
https://www.northamericanmotoring.co...feed-line.html
I purchased mine at Way(https://www.waymotorworks.com/wmw-st...-line-kit.html) and after 2 years its working great, no leakages at the oil line, now have to worry about leakage at the valve cover gasket and oil pan gasket, you just cant win with this engine.
Old Sep 21, 2016 | 01:20 PM
  #36
Lex2008's Avatar
Lex2008
Originally Posted by gcaspelich
...now have to worry about leakage at the valve cover gasket and oil pan gasket, you just cant win with this engine.
Dont forget the vacuum pump o-ring and the oil cooler gaskets. The latter is a major major PIA.
Old Sep 22, 2016 | 11:00 AM
  #37
After the oil feed repair& turbo removed I feel a lack of power and ,I think, a new whoosh noise????????? Am I imagining things?
Turbo boost leak?: I took the car out for a good run and I feel a lack of power (boost) I could never get my foot to the floor before, now I can
I will bring it back tomorrow
Any similar experiences out there?
Old Sep 22, 2016 | 12:37 PM
  #38
Lex2008's Avatar
Lex2008
ya sounds like you/they? didnt seal something all the way. Take a water spray bottle and spray around the joints to see if you see pressurized air coming from between the joints.
The turbo doesnt need to come off for that job.
Old Sep 22, 2016 | 02:31 PM
  #39
DneprDave's Avatar
DneprDave
The turbo recirc valve may be stuck open.
Old Sep 22, 2016 | 05:25 PM
  #40
Thanks guys........Have been reading about a boost test. Would this be the way to confirm before going on to the steps you mentioned ?
Old Sep 23, 2016 | 04:01 AM
  #41
DneprDave
This plug was loose; When I plugged it in firmly It made a big difference
woodstudio
Mar 15, 2020 08:28 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
ASRman
Aug 13, 2015 09:33 AM
