R53 JCW Supercharger Pulley sound
Old Oct 28, 2011 | 06:03 PM
slowjetta's Avatar
slowjetta
I think my supercharger pulley may be going bad, what will this sound like? It does appear to be coming from the pulley when hood open but could this be the tensioner as well? Anyone have any advice as to what else I should look for?
Pardon ignorance but first supercharged vehicle
From what most forum posts JCW pulley is 15%. Could someone confirm this?
Old Oct 28, 2011 | 06:35 PM
TimL's Avatar
TimL
Can't help you w. the sound of a dying SC -- the pulley's basically just a metal disc, there's not really much to "go bad" -- but I believe the JCW pulley is closer to a 12% reduction rather than 15%.
Old Oct 28, 2011 | 07:06 PM
fireaxxe's Avatar
fireaxxe
JCW is 14.6% from what I've read.
Old Oct 28, 2011 | 07:19 PM
slowjetta's Avatar
slowjetta
Bearing?
Isn't there a bearing that can go bad within the pulley?
Old Oct 28, 2011 | 07:26 PM
TimL's Avatar
TimL
Originally Posted by k-huevo
The JCW pulley is 10.9161793% smaller than the standard pulley; stock 2.565 in., JCW 2.285 in. I can imagine how the mistake has been perpetuated because I believed the 14.8% myself until I performed the measurement; that’s why I encourage each of you with an interest to be hands on and measure it.
https://www.northamericanmotoring.co...90-post12.html
Old Oct 28, 2011 | 08:22 PM
slowjetta's Avatar
slowjetta
TimL's got down to the %
Nice man! thx for digging that up
Maybe I'll record the sound best I can, someone may recognize
Old Oct 28, 2011 | 08:28 PM
daflake's Avatar
daflake
There is plenty that can fail in the SC. There are a set of gears in the rear that drive the water pump that can disintegrate. It is generally a rattling sound that is heard coming from the SC. The pulley itself won't go bad, but it isn't uncommon for the SC to fail
Old Oct 28, 2011 | 10:45 PM
BlwnAway's Avatar
BlwnAway
What year is the car?
Usually '05 & '06 w/p gears will make noise before the s/c goes
Earlier years it's a toss up.
(Do the screwdriver test or get an autimotive stethascope to determine exactly where the sound is coming from)
If it's the w/p gears, you may be able to prolong their life by simply doing an s/c oil change, usually the gears themselves will only go bad from the oil seeping into the s/c and the compartment going dry. But yes the s/c bearings do fail also, but that is more common in '04 and earlier.
If you think it's the s/c or the w/p gears and decide to "drive it till it drops" just watch your temp. gauge, the w/p will prob. be the first sign of complete failure (besides the rattle getting louder) and you din't want to overheat the car. (I actually drove more than a year from the time they started making noise.
Good Luck.
Old Oct 29, 2011 | 05:23 AM
ZippyNH's Avatar
ZippyNH
NOPE...the oem pulley is a hot pressed machined steel disc...held on by the thing cooling, and the hole shrinking onto thr shaft.
the pulley has been said to be 11.45% smaller, but it has been reported as many different %'s....accurecy when measuring down to a few % is hard...just know it is a bigger pulley than 15%.
Old Oct 29, 2011 | 05:32 AM
BlwnAway's Avatar
BlwnAway
This being said, if you do replace the s/c get a 15% or smaller put on it then. (if you want a little extra performance that is.)
Old Oct 29, 2011 | 09:00 AM
slowjetta's Avatar
slowjetta
Thanks guys, appreciate the quick suggestions.
Don't know if this helps but my mileage has not changed at all, but there is a slight "doggyness" to the acceleration when in low gears, gets better 3rd forward. I'll link to a YouTube vid, maybe that"ll lend some better help as well
Old Nov 3, 2011 | 10:04 AM
slowjetta's Avatar
slowjetta
Could someone take a look at this video. Curious opinions: waterpump pulley, supercharger pulley maybe? gasp....supercharger itself dying???!!!
No change in gas mileage since noise
Very audible by right front tire
slight lag in acceleration 1-3 below 3K, fine above 3K and pulls good and hard.
Video Link:
Focused on supercharger pulley, and it seems to rotate nice and smooth
Clarification needed is there a bearing beneath the pulley?
http://dl.dropbox.com/u/22868815/IMG_0888.MOV
Old Nov 4, 2011 | 05:20 AM
slowjetta's Avatar
slowjetta
Supercharger pulley Video
Could someone take a look/listen to this video in the link? Curious if anyone out there could shed some light on the cause of the noise.
Focus of video is on supercharger pulley which appears to be making the noise.
Waterpump pulley, supercharger pulley....gasp supercharger itself?
Old Nov 4, 2011 | 05:24 AM
slowjetta's Avatar
slowjetta
Bad Link Sorry
Heres the video:
http://dl.dropbox.com/u/22868815/IMG_0888.MOV.zip
Old Nov 4, 2011 | 05:25 AM
slowjetta's Avatar
slowjetta
Video: Good Link
This should work:
Old Nov 5, 2011 | 05:31 PM
K20K1LLA's Avatar
K20K1LLA
Sounds like a timing chain tensioner. It's a common failure amongst the R53s. Barring that, the accessory belt tensioner damper goes bad too. Rest assured, is most likely NOT the SC.
Old Jan 4, 2012 | 07:51 PM
mernbrad's Avatar
mernbrad
Check the supercharger oil. I had to replace my supercharger when the oil leaked out.
Old Apr 16, 2012 | 04:12 AM
Webhead68's Avatar
Webhead68
Just got done replacing my supercharger. Oil was gone in the rear chamber, bearing failed on PTO and gears were shot. Water pump was rattling a little too.
bobbiemartin
Jan 20, 2016 05:28 PM
Toolman
Jan 20, 2016 06:50 AM
JPMontes3
Aug 23, 2015 01:26 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
