rubber burning
Old Aug 31, 2011 | 09:50 PM
luvminiluv's Avatar
luvminiluv
rubber burning
My MCS 2005, 90K starts smelling like rubber burning, then I lost power (the car is moving no more than 3 miles/hour. now after 5 days sitting in the garage, the car is driving normal.
I just wanna know what's wrong with the car, and is there anything I need to fix, Thanks.
Old Sep 1, 2011 | 08:27 AM
Gizmo's Avatar
Gizmo
This would get more views if it were posted in the correct forum... This is for Classic Mini related topics.
Old Sep 1, 2011 | 09:33 AM
GBMINI's Avatar
GBMINI
You left the e-brake up while driving?
Your clutch is slipping?
Old Sep 1, 2011 | 10:12 AM
quikmni's Avatar
quikmni
Crankshaft pulley coming apart?
Also check the serpentine belt. Is it coming apart? Does it look like it was slipping? Are all the pulleys rotating freely (any noise)?
Was the A/C ON when the problem occurred and now it is OFF?
Maybe the A/C compressor or pulley is not working correctly.
Old Sep 1, 2011 | 01:26 PM
ZippyNH's Avatar
ZippyNH
Crankshaft pulley is my bet.
Old Sep 1, 2011 | 07:16 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Burning rubber is most commonly a broken crank pulley. If that is the case replace it with an ATI damper so it doesn't happen again.
Old Sep 17, 2011 | 11:31 PM
mini b's Avatar
mini b
It's the crank pulley. Just had the one on my POS replaced.
Old Sep 18, 2011 | 06:18 AM
minsanity's Avatar
minsanity
+1 on crank pulley possibility & ATI
Old Oct 5, 2011 | 06:54 PM
MINI-Speed's Avatar
MINI-Speed
2% Overdrive ATI...opinions
Is anyone running the 2% Overdrive model of the ATI Super Damper?
Any opinions, noticeable changes, recommendations to go with the 2% or stock size version?
Planning to purchase one soon.
Thanks in advance!
Jason
Old Oct 8, 2011 | 11:19 AM
MINI-Speed's Avatar
MINI-Speed
2% Overdrive ATI Super Damper..opinions
Thanks in advance!
Jason
NO ONE is running the ATI 2% overdrive
Old Oct 8, 2011 | 02:12 PM
ZippyNH's Avatar
ZippyNH
Adding the overdrive pulley is an easy way to get an extra 2% of reduction from a 15% pulley more or less, giving you a 17% (equivelent of a 17% sc reduction pulley).
Imo staying with a dampened pulley is the way to go..
But some do go with an undampened one to save $$, but putting longterm longevity at risk.
Old Oct 8, 2011 | 03:53 PM
quikmni's Avatar
quikmni
I plan to go with the 2% crank pulley to go with my 12% JCW S/C pulley.
Old Oct 9, 2011 | 08:07 AM
MINI-Speed's Avatar
MINI-Speed
I've got a stock non-JCW with stock pulley. I don't plan on upgrading to a 15% reduction pulley. If I do get the 2% Overdrive ATI Super Damper, do you think I will have to change the belt to a smaller belt or even a JCW belt or can I go with a new stock belt?
New crank pulley to replace the vulnerable stock crank pulley and get an performance improvement the same time!
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
