Dealer CAN'T reproduce my idle and clutch problems! So typical.
Old Sep 26, 2011 | 08:12 PM
  #26
cub4bearindiana's Avatar
cub4bearindiana
Originally Posted by JustanotherTech
Old thread, but I figured I would help you guys out. Im a tech at MINI, and I have seen a few of the problems you mentioned before. The clutch pedal "knocking" is the clutch pedal hitting the slave cylinder next to the pedal under the dash. Take it in to the dealer and tell them to replace the clutch pedal bushings. I've done it numerous times and it fixes EVERY car that I have done it on.
and to the headlight washers....they are now optional. Not sure if any of you knew that or not, but its an extra $100 or so to get them to where they actually work and have all the plumbing.
EDIT: They have to replace the whole pedal assembly and the spring (along with other minor pieces)with the bushings. It should be covered under warranty for most of you.
on the other note.. can I just drive my car with the clutch acting like that for now? I figure, that maybe for my first oil change I would make it to happen and replicate it for dealer.. just not sure how safe is that?
Old Sep 26, 2011 | 09:22 PM
  #27
PatM's Avatar
PatM
Based on what I heard from the tech that told of the fix, my guess would be that you can drive the car till the cows come home and you won't have any problem. Sounds like more of an annoyance than a safety or failure type issue.
Just my educated guess from what I read here.
Regards.
Pat
Old Nov 1, 2011 | 07:00 PM
  #28
BAD69BIRD's Avatar
BAD69BIRD
head light washers are now an option, for a few short months of productions if you ordered xenons you got washers with no plumbing, now they have dummy plugs
Old Nov 1, 2011 | 07:02 PM
  #29
cub4bearindiana
yup.. learned that pretty quick... got new lights though, the RIGHT ones which supposed to be there from beginning.
iggi
18
Feb 9, 2026 01:00 AM
eliseo1981
Jan 28, 2021 02:45 PM
Zettinger
Aug 25, 2015 04:04 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
Lt. Dan
Aug 10, 2015 08:23 AM
