No jump from front battery post
Old Aug 21, 2011 | 11:54 PM
jmoser's Avatar
jmoser
my 2002 MCS,
the battery post in the front of my engine definitely is connected to the battery in back, but hell will freeze over before you can jump the battery using that terminal.
I have had tow truck drivers try and try...when you pull everything out of the back, lift the cover and charge directly to the battery,
vroom, fires right up.
but its a pia and could be a safety hazard too...
and why else would there be a front battery terminal if not to jump from?
anybody else have this problem?
been to my local dealer years ago, I won't even bother to tell you what they said...
maybe its time to go back again and see if they could make it right...the management has changed there about 6 times or more...
Old Aug 22, 2011 | 02:04 PM
thulchatt's Avatar
thulchatt
I thought the front posts were only so you could give a jump to another car.
I would not want to run the current through the car to get a jump. I would much rather jump right to the batter terminals.
Old Aug 22, 2011 | 03:35 PM
rkw's Avatar
rkw
The Owner's Manual says it is for receiving a jump. Step-by-step instructions tell you to connect the jumper cable exactly there.
Old Aug 22, 2011 | 03:47 PM
ofioliti's Avatar
ofioliti
I've given a couple of successful jumps from the front, but have never had to receive a jump. (It's good to know that there is the rear/direct option if the front fails, if I ever need a jump. I have a still-running-strong 8-year old oem battery.)
Old Aug 22, 2011 | 05:59 PM
jmoser's Avatar
jmoser
First time I spoke with the dealer, they acted like it should work. I"ll check again.
Anybody else, have you ever jumped your car to start your battery using the
front battery post?
Old Aug 22, 2011 | 06:03 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I've never needed a jump. But I have had to gravity/push start a few times.
Old Aug 23, 2011 | 10:47 AM
thulchatt's Avatar
thulchatt
Thanks, good to know.
Old Aug 23, 2011 | 11:17 AM
rkw's Avatar
rkw
Well, at least that's how MINI designed it to be used, but it's going to depend on the condition of the cable and its connection. There are clearly some issues with it in the OP's MINI. I'm not surprised that it deteriorates over time.
Old Aug 23, 2011 | 02:14 PM
thulchatt's Avatar
thulchatt
I think we may be agreeing that jumping at the battery is OK, maybe even better.
I would not jump from the posts under the hood but your point that the manual says it is how to get a jump is good info.
Kimolaoha
Jul 5, 2023 01:04 PM
stevepsd
35
Dec 6, 2022 03:22 PM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
emulajavi
Dec 24, 2018 09:15 AM
FLYM1N1
Aug 15, 2015 11:20 AM
