AC issue due to lowering???
Old Oct 20, 2011 | 12:03 PM
  #51
EcoHeliGuy's Avatar
EcoHeliGuy
Auo correction on iPad
Fluorescence
Old Oct 20, 2011 | 12:33 PM
  #52
Bigprfed22's Avatar
Bigprfed22
lol didnt work that time :-p
Old Oct 20, 2011 | 01:06 PM
  #53
EcoHeliGuy's Avatar
EcoHeliGuy
I give up :P
Old Oct 20, 2011 | 07:31 PM
  #54
tintman718's Avatar
tintman718
Originally Posted by tintman718
Just an update: my a/c is inop. Going to inspect and report back.
Old Oct 17, 2012 | 07:55 AM
  #55
SooperCuperErik's Avatar
SooperCuperErik
Ever figure out the reasoning tintman? Mine was working and 30 min into drive I noticed it was ambient air coming in... Compressor still turns on but no cold air. Hoping its not the condenser.
Old Apr 11, 2013 | 07:03 PM
  #56
MNMLST's Avatar
MNMLST
Sorry for resurrecting this thread.
My 2011 R56 is lowered with H&R Streets by 1.5 inches on the front and inspection shows signs of rubbing on the a/c line. It doesn't look bad; the spot just looks polished. I'm guessing the line only makes contact with the axle during suspension compression and hard left turns. I raised the suspension a bit to give it some clearance.
My question is will a layer of aluminum tape provide some protection from wear caused by occasional contact with the axle?
Old May 14, 2013 | 08:56 AM
  #57
Mindspin311's Avatar
Mindspin311
I think Im running into this issue as well. I have a clunking noise from the right front, but everything seemed tight when I checked. I will have to inspect the AC line this weekend.
Old May 20, 2013 | 02:00 PM
  #58
Mindspin311
I had a few scratches on my AC, also the plastic clip that held the line, it attaches to the block and it was actuall broken off. So I guess some sort of impact jarred the line enough to break that screw which held it in place.
I tried looking at RealOEM, but the diagrams look the same for both an 07 and a 13.
I ziptied the line out of the way, but then realized that the point at which we are all ziptying from is on the body. I am worried that tying it to the body when the engine rocks will cause some issues.
woodstudio
Mar 15, 2020 08:28 AM
W0TM8
Dec 19, 2019 07:50 AM
cerenkov
Apr 24, 2018 07:47 AM
Minibeagle
Aug 13, 2015 10:00 AM
ASRman
Aug 13, 2015 09:33 AM
