Just replaced power steering fluid return hose (pics)
Old Aug 5, 2015 | 07:25 AM
  #51
Mr Xshun's Avatar
Mr Xshun
Can I use generic power steering tubing to replace the supply line and just re-use the old shielding? I don't want to spend $40 plus shipping if I don't have to.
Old Aug 5, 2015 | 07:38 AM
  #52
mikes603's Avatar
mikes603
Why even spend $10 on fancy power steering tube? Just use garden hose.
Old Aug 5, 2015 | 08:04 AM
  #53
Mr Xshun's Avatar
Mr Xshun
If I'm going to use a garden hose, why not make it out of paper mache?
Since more specifics are apparently needed, are there components of the supply line included in a stock line that I don't see when I look at the shielded line sitting in my car? I'll pay the money for a new line if there is a good reason for it but I don't want to spend the money if I don't have to.
Old Dec 18, 2015 | 07:51 AM
  #54
MinEff's Avatar
MinEff
Does anyone have the Original Posters image? inageshack has deleted them :(
Tha ks in advanced
Old Dec 18, 2015 | 10:57 AM
  #55
Here. All in order to match the first page.
Old Dec 18, 2015 | 11:58 AM
  #56
MinEff's Avatar
MinEff
What a legend! I've spent $800 on ECS in this project alone, would have been $6000 at the dealers, you guys are doing Gods work, thank you!
Old Dec 18, 2015 | 12:13 PM
  #57
You are welcome.
Old Jan 4, 2016 | 12:48 PM
  #58
edgy's Avatar
edgy
Originally Posted by TigerDave
Thanks to the members, I was able to replace the power steering fluid return hose on my 2006 S. The fluid return hose appeared to be dripping onto the power steering pump which then bled onto the garage floor.
It took 5 hours start-to-finish (because I took my time and had to make two runs to find the right sized socket (22mm), swivel adapter, and extension bar to access and remove the bolt).
The replacement hose was $68 at Pelican Parts. The fluid was $22. The crush washers they sent me were the wrong part (too small) so I was forced to re-use the existing ones. Will keep an eye on it and if they leak, I'll buy the correct size (which means draining the PS fluid again (messy and pricey).
Here are some pics of what I saw.
Not getting the pictures loaded - get a "404 error" - have these pictures been moved? Thanks either way...
Old Jan 4, 2016 | 12:55 PM
  #59
I posted them above in order. Post #55.
Old Jan 4, 2016 | 12:59 PM
  #60
edgy's Avatar
edgy
You're helping me make the case for a big screen in my man cave garage!
Old Jan 4, 2016 | 01:01 PM
  #61
Thats Man Cave 101
1. Big Screen TV
2. Bar
3. More Car Lifts
4. More Tools
5. More MINIs
Old Jan 4, 2016 | 01:05 PM
  #62
edgy's Avatar
edgy
I've got most of the list - two Mini's, a 2002 MCS, 2008 Clubman, plus an Arctic Cat with snow plow..., I've got two floor jacks (but no jackstands yet!) ramps to pull the car up for oil changes, lots and lots of tools, a pretty awesome sound system (used to be in the house) and a microwave. Need a keg-o-rator and some heat - it's pretty chilly this time of year! I expect I'll find that out tonight when I begin crawling back around L'il Red!
Old Jan 4, 2016 | 02:07 PM
  #63
Propane or Kerosene Jet heater is what you need. Heats up quick and can d a big garage. Have one and it works well.
Old Jan 7, 2016 | 12:27 PM
  #64
edgyedgy
Did you get the p/s hose kit done ?
Old Jan 11, 2016 | 02:46 PM
  #65
edgy's Avatar
edgy
edgyedgy
Not yet. It's pretty cold out to do much laying around on the floor of the garage. And I have an F350 for when the weather is wintry so I have been slow to attend to it. I put the car up on ramps and got under it - i still needed to jack the body up as the ramps are great for oil changes when you know what you're looking for. Not as helpful to see where the leak is coming from. I'd like to know that before I begin buying parts. There has to be a leak as the reservoir is almost empty and it left a big mess on the garage floor, mostly confined to a tray I had thoughtfully placed under the car for just such an occasion. I can see the P/S fan and pump but the fluid seems to come from above, possibly in front of the pump. I am wondering about the P/S rack. There doesn't seem to be any problem with the connections at the bottom of the reservoir. I can't get a good look at the underside, however. Might have to take it to my local tire place just to get it up high enough to take a good look.
Old Jan 11, 2016 | 02:49 PM
  #66
Yea, you need to get under it or up on a lift.
Old Feb 5, 2017 | 11:18 AM
  #67
2seven's Avatar
2seven
Hello NAMers, I replaced a leaking return hose (purchased from ecstuning.com) yesterday and to my disappointment I woke this morning to find a puddle of power steering fluid in my driveway. I didn't know the torque specs for the hollowed bolt so I simply wrenched it down nice and snug. Obviously not snug enough. Does anyone know the torque for this bolt?
Old Feb 5, 2017 | 12:29 PM
  #68
rwkeating's Avatar
rwkeating
From Bentley Manual 2002-2006
High pressure line to steering pump 10 nm (89 in-lb) (page 320-15)
NOTE THIS IS pounds per inch (not foot pounds)
Fluid lines to steering rack and it says to replace the seals (page 320-18)
high pressure 34nm (25 ft-lb)
low pressure 40 nm (30 ft-lb)
Old Feb 5, 2017 | 09:57 PM
  #69
2seven's Avatar
2seven
Thanks for the reply rwkeating. A friend of mine, professional mechanic, sent me the specs. The problem doesn't appear to lie within the work I've done, rather in the work I have not. While jostling the reservoir to remove the return hose I loosened the seal of the supply hose. The car is 10 years old, I should have purchased the entire kit and replaced both hoses. Rookie move.
Old Feb 8, 2017 | 05:49 AM
  #70
Thanks for the order, glad you got the specs. Yea, doing it all at once saves from doing it again. Glad its fixed.
Old Feb 21, 2017 | 09:45 AM
  #71
zsqure's Avatar
zsqure
I have both hoses to replace on my '04. Need to locate the 22mm socket. Waiting on the exhaust header to show up so I can do that too. Any benefit to dropping the header out first?
Old Feb 22, 2017 | 04:55 PM
  #72
2seven's Avatar
2seven
Sure, dropping the exhaust manifold will definitely provide you a bit more wiggle room to install the supply hose as long as you remove the heat shield that lies between the manifold and the power steering rack. The return hose is fairly easy to access with the front driver's side wheel removed and use of a universal joint and extension added to your ratchet. Don't forget to use both washers when installing the banjo bolt at the bottom of the return hose.
Old Feb 24, 2017 | 10:09 AM
  #73
zsqure's Avatar
zsqure
Swapped out the hoses last night, what a bear. No 22mm socket so I used a 22mm box end wrench on the banjo bolt. Will have to locate a socket so I can torque it to the proper value. Just finger tight so it will leak/purge the air when I fill it as a reminder. What a mess of grit /sand under there. I guess I should have hit the area with gunk and the pressure washer. So, the PS cooling fan was tight (no spin). Took it down and freed it up somewhat. Is the fan included in the recall? My PS pump looks new. Some BMW web site (input my vin) says my car is eligible for the recall. Leaking cooling hoses are next.
Old Feb 24, 2017 | 10:50 AM
  #74
Pump and the fan, most of the time the fan gets gunk / between the fan blade and housing itself. If it blows out and spins clear, then test it with turning on the AC and let the car idle, the little PS fan should kick on, it not its bad.
The recall is on certain years. And if you had the pump replaced before or the fan, you might want to check on it because MINI is checking the older part numbers on those to replace.
https://www.northamericanmotoring.co...ng-recall.html
Old Apr 15, 2017 | 12:35 AM
  #75
LordOfTheFlies's Avatar
LordOfTheFlies
Can you use a O2 sensor socket for the banjo bolt?
I need to replace my O2 sensors so I bought this 22mm socket:
Amazon Amazon
