small oil leak after oil change?
Old Mar 20, 2011 | 07:39 PM
nitrogen76's Avatar
nitrogen76
I dunno what's up.
'05 Cooper S. I change the oil yesterday, and now, after sitting, it seems that about a teaspoon of oil will be under teh oilpan. I can't tell where it's coming from. there doesn't seem to be any oil by the drainpan or the oil filter.
The oil looks absolutely clear, though, which is puzzling, because I am pretty sure I didn't spill any...
Old Mar 20, 2011 | 08:09 PM
Evasive's Avatar
Evasive
You sure it's not coming from your drain plug? Might want to wipe everything dry and check it out a few hours after to see where it's really coming from.
Also, might want to make sure you're not mistaking it for coolant. It's clear and almost has an oily feel to it. I thought mine was oil but turned out to be the thermostat.
Old Mar 20, 2011 | 08:26 PM
nitrogen76's Avatar
nitrogen76
I'll wipe the drainplug and re-tighten it. I also just realised I probably overfilled the oil by about half a quart, too. Dummy me.
Old Mar 20, 2011 | 08:32 PM
Evasive's Avatar
Evasive
I suggest getting rid of the excess oil instead of letting it burn. If you have a topside oil extractor or know someone with one, that will do the trick. Otherwise drain the oil and if you can't afford to pour new oil, then make sure you drain cleanly.
Old Mar 20, 2011 | 08:50 PM
nitrogen76's Avatar
nitrogen76
REally, for half a quart? I don't see any bubbles on the dipstick after running it. I know certain folks recommend an extra quart for performance driving, but I dunno about these cars
Old Mar 20, 2011 | 08:56 PM
Evasive's Avatar
Evasive
You might be okay with half a quart but I always prefer to be within spec to be on the safe side. Overfilled oil can lead to carbon build up or faster degradation of your catalytic converter.
Old Jul 5, 2020 | 09:51 PM
OCR's Avatar
OCR
Delete
speedman
16
Mar 11, 2020 11:17 AM
k_h_d
Oct 18, 2008 03:57 PM
nabeshin
Oct 13, 2006 05:59 PM
gtbuzzmini
Classic Mini Talk
Jul 1, 2006 12:25 PM
Nick_T.
12
Jun 8, 2004 08:30 AM
