reservoir cap missing
Old Feb 1, 2011 | 07:01 PM
Louispup's Avatar
Louispup
In my pre-MINI life, I was a car killer. So I guess I know what I need to do. But I've already written the rest of this, so here goes. I was running hot tonight (fortunately I needed and had my defrosters on). I checked and my coolant reservoir cap was gone.
I don't know how long it's been gone. Now that I think about it, I heard a "pop" when shutting her down the other day when idling (again, running hot). And I've driven a fair bit since then. Obviously I should have checked the coolant right then. I turned on the blowers and that cooled things down. Yes, I'm ashamed I didn't look right into it.
The level Tonight (when it occurred to me to check) was just under min. I poured some filtered water in to bring it just above min. OK, I also "smithed" an aluminum cap for it, and tightened it shut.
So now I realize I need help. What do I do? I've been driving like this for days. I've shocked that it's still running without fail. And surprised now that I realize what that "pop" was, that it has any fluid in it at all.
I guess I'd like to drive it in to my mechanic in the morning, but I don't think anybody's going to agree with that. I'm so spoiled with this little car working so well that I overlook things like keeping an eye on the fluids and of course I'll know better next time. Having had the thermostat replaced while under warranty, naturally I thought my coolant issues were gone for good.
Mea Culpa. I guess I should just get another ride into town tomorrow and pick up some coolant from my mechanic or the dealership? And what about the blown cap? Can I replace the reservoir unit myself? Thanks much.
And I hope you have a great ride.
Old Feb 2, 2011 | 07:17 AM
Louispup's Avatar
Louispup
I left her in the barn this morning. Waiting to hear from my mechanic.
I was tempted to crank the engine to watch the reservoir, but left it alone.
If the radiator is spent or worse, should I be hearing bells or whistles (or worse)? Thanks in advance for your kind consideration.
Old Feb 2, 2011 | 07:57 AM
ZippyNH's Avatar
ZippyNH
Sounds like the cap was just not on propperly.....and popped off from the pressure...
Filtered water is as bad as tap.....use distilled water....filtered water can still have a very high mineral content.
As for coolant....add more of the same type you are using. If it is blue....it is bmw/mini coolant....a somewhat unique hybird chemically.....do not add "universal" coolant....if the level was ok....you might just need yo check the concertration/ freeze protection level, add a new cap and be good....but if the level was very low, a bleed might be needed to prevent a possible overheating from a trapped airbubble.
Old Feb 2, 2011 | 08:30 AM
Capt_bj's Avatar
Capt_bj
my guess too is that the cap was simply not on tight. Get a new cap and top things off is all I'd do for now.
Comment about need for a bleed is right on too, and if you DO still see high temps it is the first thing I'd try next.
I'm not sure why you would need a new resiv' but on an S replacing one takes about 10 minutes. One bolt and two hoses as I recall. I've replaced mine and a couple for others. A little different on a justa but not much more difficult so far as I can tell. Got the wrong bottle once so know what it looks like, but have only actually changed S models
As I recall the new bottle did not come with a cap ... that is sold sep' so check. If it did, I'd expect to have several caps in my left over parts box.
Old Feb 2, 2011 | 09:13 AM
Louispup's Avatar
Louispup
OK. Thanks ZippyNH and Capt bj.
I have no coolant (and don't know how to bleed). Should I have it towed (in case of airbubble), or, should I go to the dealership while out today, pick up some fluid and a cap (and distilled water), and add those / see how it does?
The stem the cap goes on may be damaged. I recall that the cap had a flip top (?). Will a new cap "snap" right on?
Thanks again for your advice!!
Old Feb 2, 2011 | 09:14 AM
Eric_Rowland's Avatar
Eric_Rowland
The cap allows a higher boiling point so the car doesn't overheat. Given the winter weather, that hasn't been an issue for you. I can't see any rational reason to do anything other than top it up (with distilled) put a new cap on it. You will not have done any damage to the radiator. The only possible issue would be ingestion of dirt/crud, so you could flush it if that makes you feel better, but that would be merely a precaution.
Now had your brake fluid cap been off - you'd definitely need a fluid flush, but coolant doesn't have the same issues.
edit: No need to tow it. The cap is a screw top, not flip top.
Old Feb 2, 2011 | 09:55 AM
Louispup's Avatar
Louispup
I'm feeling better now. Thanks Eric!
Old Feb 3, 2011 | 12:46 PM
Louispup's Avatar
Louispup
Had a great visit to MOB last night. Saw the new models, bought the $5 part. Fixed it in five minutes. Thanks for your assistance, everyone.
patsum
26
May 29, 2021 06:29 PM
Grizld700
Sep 15, 2015 05:34 AM
freckles81
Sep 8, 2015 09:48 AM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 03:01 PM
