Very very simple question
Old Jan 28, 2011 | 08:42 AM
Fei's Avatar
Fei
I was trying to bleed the clutch slave cylinder last night.
I unbolted and later wanted to put it back.
I hand compressed it but couldn't slide it back in, so I forced the cylinder piston in the front and tried to slide it in at an angle.
Sadly, I saw brake fluid started dripped from the front, where the boot was bone dry before. The brake fluid stopped dripping after I straightened it back.
But did I just screw up the clutch slave cylinder and should buy a new unit?
Old Jan 28, 2011 | 10:15 AM
Vollgas's Avatar
Vollgas
You need a slave cyl. compressor to do the job correctly.
The shaft has probally wiped out the seal when installing at an angle.
Old Jan 28, 2011 | 10:18 AM
Fei's Avatar
Fei
Thanks, i hope the seal is still okay, just leaked a bit when yanked.
Old Jan 31, 2011 | 10:41 AM
Fei's Avatar
Fei
I called a mechanic from a dealership, and was told that it was designed to sip a bit to lubricate, and most likely mine is still fine.
I bled all the brakes and the slave cylinder. The car is still driving fine. Will wait and see.
Colt45Magnus
Aug 27, 2024 05:03 AM
Manny_cooper
Sep 3, 2015 05:48 AM
Ladybug-S
Sep 1, 2015 07:07 PM
broncobuddha
Sep 1, 2015 06:32 PM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
