Idle issues
Old May 16, 2011 | 12:15 PM
  #26
mrdunn's Avatar
mrdunn
rough cold idle and rough engine
When cold, my clubman s 2008 (18000 mile) acts like the old cars did when you didn't pull the choke out when cold, it "bucks" for about a mile and has a rough idle. Took to dealer, said use only Chevron gas "because there are no error codes, must be the gas". Is this the same problem as this thread is about, or a different problem?
thanks
Old May 16, 2011 | 04:11 PM
  #27
Arnold68's Avatar
Arnold68
Very similar to my problem except I usually let the idle smooth out before I drive away. Your problem sounds more serious then mine since yours bucks. Mine does buck a little but not too bad if you drive away right away after starting. So has the Chevron fuel resolved your problem?
Old May 16, 2011 | 04:16 PM
  #28
mrdunn's Avatar
mrdunn
not yet, they also told me to add chevron Techron fuel system cleaner. I am dubious, since I usually use chevron gas, and the problem just started a couple of months ago. Just wondering if the advice makes any sense, and if the lack of an error code really rules out a engine problem. Thanks for the reply.
iggi
18
Feb 9, 2026 01:00 AM
gmcnaugh
Oct 27, 2018 03:42 AM
Marco Guardado
Sep 15, 2015 01:22 AM
robbiedowns22
Aug 25, 2015 12:20 PM
Lt. Dan
Aug 10, 2015 08:23 AM
