Fluid Leak
Old Dec 15, 2010 | 01:07 PM
xristos's Avatar
xristos
Fluid Leak
My car was sitting in the garage for a couple of days because of the sudden snow fall and I noticed a large pool of blue thin oil below the engine. I opened the power steering reservoir and it was empty, it seems that the all the fluid leaked on my garage floor. I’m trying to locate the leak. It’s not from the bottom of the reservoir where the hose connects. Then I raised the car a bit and took a look at the other end of the hose and that too seemed ok. My question is where did the fluid leak from? Is it from the pump?
Old Dec 15, 2010 | 02:45 PM
ZippyNH's Avatar
ZippyNH
You just have to find it...
Things can fail many ways...
The pump, the hoses (low or high preassue)
The seals on the rack..
Nobody can track it down for ya!!
Sorry, just the truth!!
Old Dec 15, 2010 | 03:30 PM
xristos's Avatar
xristos
Thank you for the input, ill take a look around.
Old Dec 15, 2010 | 04:38 PM
ZippyNH's Avatar
ZippyNH
If you clean up the area, then turn the car on, and have a helper turn the wheel...watch...then turn the car off, look for fresh fluid! It might help.
Old Dec 15, 2010 | 06:20 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If it's a blue fluid it's prob coolant, check the thermostat.
Old Dec 16, 2010 | 01:23 AM
xristos's Avatar
xristos
Its from the power steering reservoir since it is empty and if i dare to move the steering wheel it kind of stumbles and makes ALOT of noise. I guess im whishing that the leak is not from the pump since it is so expensive. Do pumps leak or do they just die. If researched around on this forum and i don't have any "symptoms" of a failing pump (sudden loss of power steering, or the power steering pump fan working when the car is off)
Old Dec 17, 2010 | 08:21 AM
rbb's Avatar
rbb
what if the color of the coolant is like a orange?
Old Dec 17, 2010 | 08:32 AM
ZippyNH's Avatar
ZippyNH
Then your car is running DEX-COOL long life antifreeze...
BMW/Mini stuff is blue, and is a special...a bit of a hybird of technologies...
Dexcool is not reccomened by even is manufacture on cars that are not equipped with it from the factory...it has causes many issues in many cars....including a class action lawsuit if I remember right...
The PS fluid, when new is kinda greenish/blueish...
I second the check the coolant...the color of the P's fluid changes pretty quick....
Old Dec 17, 2010 | 08:37 AM
ZippyNH's Avatar
ZippyNH
The fact the op said it was oil like...not watery makes me think it is possibly the P's fluid...
Put some fresh fluid in, and see where the fluid leaks out!!
Old Dec 21, 2010 | 02:33 PM
mejerry's Avatar
mejerry
xristos,
Any luck? I just had the same situation. Moved my MC and found oil patch on driveway. PS pump reservior empty. Purchased new fluid ($20 qt, ouch). Have local mechanic looking at right now. Zeroing in on clamp around the plastic reservior attached directly to the pump (not the reservior located on firewall near top of engine bay.
Old Dec 21, 2010 | 02:56 PM
xristos's Avatar
xristos
One of the clamps was loose or needed replacement. NOT from the reservoir to the pump, a clamp after the pump.
This might help....
http://www.realoem.com/bmw/showparts...67&hg=32&fg=20
Old Dec 22, 2010 | 05:54 PM
mejerry's Avatar
mejerry
xristos,
Just got mine back. Hose Clamp (part #3211113134) at pump on hose leading from reservoir was loose. Mechanic cut clamp and replaced with new hose clamp. Tightened, cleaned, all done. Steering nice and smooth again. $75.00 labor. Plus the $20 I paid to buy the CHF 11S fluid.
Hope this helps others.
Old Dec 23, 2010 | 01:59 AM
xristos's Avatar
xristos
sweet im glad you are up and motoring again.
boholio
Nov 9, 2015 03:50 PM
IFIXEM2
Sep 18, 2015 08:47 AM
Sep 10, 2015 03:36 PM
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
