Coolant Temperature
Old Dec 8, 2010 | 08:38 PM
Thomas1's Avatar
Thomas1
Coolant Temperature
Hey everyone,
So I started my car today and after some driving I noticed that when I am at a red light stopped for a while my engine coolant temp goes all the way to the red, but as soon as I start driving the needle drops almost instantly to normal temp. I think I may have lost too much coolant through a small leak in my overflow reservoir, seeing as there is some coolant on the header heat shield. Should I fill top it off with some water temporarily? also is my diagnosis correct?
thanks for the help!
Old Dec 8, 2010 | 08:50 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes fix the leaky coolant tank and top up the coolant, then make sure the fan is coming on.
It's a good idea to use a scangauge to monitor the temp and ensure the thermostat, and fans are working. The temp gauge in the dash is just an idiot light and will stay at 1/2 till it reaches 240 deg then move so it will be too late at that time and you can damage the engine.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
vulkandino
Oct 31, 2015 08:29 PM
point665
Sep 29, 2015 12:41 PM
silence2-38554
Sep 28, 2015 12:19 PM
rt808
Sep 25, 2015 01:59 PM
