Please help identify this leak.
Old Nov 2, 2010 | 03:36 PM
dannyhavok's Avatar
dannyhavok
Hey guys, I have been losing coolant on my R50. The dealership I bought it from has not been able to find a problem, although it is a japanese oriented shop. Last night I put a board underneath the car to see if it's dripping out there. Here is a photo of the results.. there is a puddle and it seems to be coming from the red circled point. Can anyone offer any advice or information here? Thank you!
Old Nov 2, 2010 | 03:47 PM
dannyhavok's Avatar
dannyhavok
I'm sorry, apparently that isn't working quite right.
Old Nov 2, 2010 | 04:37 PM
lhigham2317's Avatar
lhigham2317
thermostat maybe?
Old Nov 2, 2010 | 04:54 PM
dannyhavok's Avatar
dannyhavok
Could be.. that seems to be a relatively common problem. I managed to get an appointment at the MINI dealership tomorrow. It's not where I purchased the car, so I will be out of pocket, but at least it'll be done right.
Old Nov 2, 2010 | 04:57 PM
daflake's Avatar
daflake
Power steering pump is right there. Could be that...
Why not find a good local mechanic? Dealer is going to cost you ca fortune.
Old Nov 2, 2010 | 04:59 PM
dannyhavok's Avatar
dannyhavok
Would I notice if there was a leak in the power steering? The car doesn't feel any different lately, and I am noticing a steep drop in the overflow tank levels.
I'm primarily taking it to the dealership because it is 2 blocks from my house and therefore pretty convenient. I may just have them diagnose and take it from there.
Old Nov 2, 2010 | 05:17 PM
dannyhavok's Avatar
dannyhavok
It looks pale green so I am assuming it's coolant. It's pretty watery, and I did top up the overflow tank with distilled water a few days ago when I first noticed it was running low. I felt around the coolant tank and wasn't able to find a leak, but I did dry everything out and am going to check again on it in a bit to see if I can find any "new" moisture.
I do have a third-party warranty that should cover it if I do need a new power steering pump or anything major. Do you have any idea what a thermostat problem might run me?
Old Nov 2, 2010 | 05:18 PM
dannyhavok's Avatar
dannyhavok
Sorry, I forgot to address that last question. I don't drive the car very hard, I do give it the occasional spirited run through the twisties but it is generally just 20km a day commuting, nothing aggressive. I have actually only put 1200km on it since purchase, mostly very conservative.
Old Nov 2, 2010 | 05:20 PM
daflake's Avatar
daflake
If it is green and watery then it is coolant and the location is consistent with the thermostat. Easily repaired for a few hundred.
Old Nov 2, 2010 | 05:39 PM
dannyhavok's Avatar
dannyhavok
Great, thank you! I did follow the leak up as far as I could, it's right around the area of the blue zip-tie in the photo. Is that consistent with the thermostat?
Old Nov 2, 2010 | 05:49 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
If the fluid is greenish, I doubt it's PS fluid.....And if the leak is at the back of the engine near firewall I would check the coolant tank bottle first.....they are a known problem.
Old Nov 3, 2010 | 03:58 PM
dannyhavok's Avatar
dannyhavok
Hey everyone, just an update. I took my car to MINI Victoria this afternoon, they called within the hour and told me it was indeed a leaky thermostat. She checked the status of my warranty and found I still have bumper to bumper coverage until Dec 22, so the thermostat is covered and they are also doing a free "MINI Clinic" to see if theres anything else I should have looked at while I'm still covered.
Thanks so much for all the help and suggestions everyone, it's great to be part of such a supportive community. I hope I'll be able to pass it on.
Old Nov 3, 2010 | 05:50 PM
daflake's Avatar
daflake
fkrowland
Sep 30, 2015 10:30 AM
point665
Sep 29, 2015 12:41 PM
daviday
Sep 25, 2015 01:31 AM
COOPT UP
Sep 11, 2015 04:59 AM
Sep 3, 2015 12:24 PM
