Power steering wire
Old Oct 20, 2010 | 10:09 PM
kbing's Avatar
kbing
Power steering wire
hi all im newbie here...
i have a 2003 r50 automatic (non S) were trying to fix my brake master cylinder and he accidentally broke the fuse box right next to the battery compartment..so we took battery compartment so we have more space to unplug ecu. adn fuse box and bought a used fuse box at miniworld..installed it and i just noticed 1 wire is not connected to the fuse box so i trace that wire and its from the power steering. can you guys help me were this thing is connected? red and green or red and red i know the big red wire goes to the fuse box but this one i dont know were my friend got this i tried asking him he forgot it too...please help me i have work friday...
Old Oct 20, 2010 | 10:25 PM
kbing's Avatar
kbing
Thanks guys got the answer i search it on google...
The PS pump wiring harness does sometimes need replacement:
Quote:
If the PS cable harness or connector is burnt or damaged it can be easily removed from a scrap MINI as it is only about 2 feet long with just 2 wires in it, only attached with cable ties (easily cut to get the loom out) and the other end, 1 wire is plugged into the bottom of the engine bay fuse box (the box is secured by 2 x 8mm headed bolts, remove them and the box lifts enough to unplug the connector) the other wire is bolted to a earth point on the chassis rail under the fuse box... (they are really thick cables, and carry alot of current so not worth trying to splice into your existing loom.) even a novice would be able to remove and refit this cable in around 20 minutes tops.
thanks...back to work friday payday
Old Oct 21, 2010 | 08:25 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We're parting out wrecked MINI's so if you need a part let me know.
WAY
info@waymotorworks.com
Manny_cooper
Sep 10, 2015 11:09 AM
bansasn
15
Sep 4, 2015 01:24 PM
Aug 25, 2015 09:33 AM
coachvminis
Aug 25, 2015 06:58 AM
minipopkart
Aug 13, 2015 05:22 AM
