SEAFOAM just in gas tank?
Old Sep 22, 2010 | 08:53 AM
jujucooper's Avatar
jujucooper
I've got some Seafoam that I use for my four stroke, but I was wondering what would happen if I poured the rest of the can into my MC gas tank. I don't have an MCS so I don't have carbon issues. Would the Seafoam just act like one of those old school STP treatments if poured into a full tank of gas?
I take lots of short/er trips, only occasionally driving for an hour or more on the highway.
Old Sep 22, 2010 | 12:24 PM
joey4420's Avatar
joey4420
I use seafoam in my Land Rovers Fuel tank one can a month. It has helped keep my fuel system happy for the last 8 years. No issues or complaints, I can't say that it has improved anything statistically, but I can say I haven't had any fuel related issues.
Old Sep 22, 2010 | 02:32 PM
minimize07's Avatar
minimize07
As I have posted here before and have had no issues relating to the *carbon build up*(an '07 MCS w/47,500 mi. hwy/city) I use techron plus every 3000 mi. or so and Shell V=Power 93 oct. and run it on the highway hard once a week.The engine still purrrs.It has worked for me....... But I also change the oil between 3-5000 mi. too
Old Sep 22, 2010 | 03:03 PM
Herleman's Avatar
Herleman
OK, I'm going to be a dummy, but -- where in the heck does one find "Seafoam"?
I've asked the local auto parts guys (Advance, and Autozone and they looked at me as if I had asked for chocolate cake icing.
Is is something folks get online?
Old Sep 22, 2010 | 03:07 PM
jujucooper's Avatar
jujucooper
I've bought it at both Advance and Autozone.
Old Sep 22, 2010 | 04:09 PM
tvrgeek's Avatar
tvrgeek
If you have a second generation Mini it does no good in the gas tank as far as carbon buildup, the big problem. It may, and I say may, help keep injectors and lines clean, but with the high ethanol content, they stay pretty clean anyway.
Now on port injection, throttle body, carb, it may do as it is intended. I prefer Red-line or Chevron myself. Only by habit, not by any data. The whole issue in DI engines is the fuel does not spray on the back of the valve to clean it.
Old Sep 22, 2010 | 04:10 PM
ScottRiqui's Avatar
ScottRiqui
I usually get it at Pep Boys, but the last few times they've been out of the simple one-pint cans.
You have to be careful to get the right stuff - there's also a Sea Foam "Trans Tune" transmission fluid additive and a Sea Foam "Deep Creep" lubricant/penetrant, neither of which is what you want for engine cleaning.
There's a Sea Foam Spray which is just an aerosol version of the regular Sea Foam liquid, so it would work as well.
Old Sep 22, 2010 | 04:43 PM
jujucooper's Avatar
jujucooper
I have a second gen, but it doesn't have DI. Only turbo models have DI on the R56.
I was thinking it wouldn't hurt either, and might do something with fuel injectors. Just wanted to make sure it wouldn't do anything negative.
Old Sep 22, 2010 | 05:05 PM
tvrgeek's Avatar
tvrgeek
Justa is port injection? Might explain their much lower frequency of repair! No need for a vapor separator either.
Old Sep 22, 2010 | 05:16 PM
Herleman's Avatar
Herleman
Am I correct in thinking that the 2010+ turbocharged motors are also port injection? I had heard that was a change this year along with the variable valve timing.
Old Sep 22, 2010 | 06:11 PM
ThumperMCS's Avatar
ThumperMCS
Incorrect in thinking.
But yes they did add dual vanos, instead of single. (variable on both intake and exhaust side)
Old Sep 22, 2010 | 06:45 PM
Herleman's Avatar
Herleman
Thanks for that information -- it seemed like a lot of change to the turbo motor all at once. If they could just get the HPFP issue fixed, I'd feel better about being in line for an 11 "S".
Old Sep 23, 2010 | 05:40 AM
smackboy1's Avatar
smackboy1
Walmart. Also can try calling marine suppliers.
Old Oct 6, 2010 | 07:20 PM
Malice Cooper's Avatar
Malice Cooper
How do the neighbors react when you do a treatment? Does the smoke take over? Are the treehuggers going to call the cops?
Old Oct 6, 2010 | 07:53 PM
countryboyshane's Avatar
countryboyshane
That's why you should do it at night. The smoke doesn't smell too good and I sure wouldn't want to be enjoying a nice sunny day and all of the sudden smelling that for 10 minutes.
scfiveo
Sep 27, 2019 02:27 PM
OutMotoring
Mar 3, 2017 06:29 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
silence2-38554
Sep 28, 2015 12:19 PM
